Oddball block
Old Sep 20, 2021 | 01:42 AM
BigEd_72455's Avatar
Exclamation Oddball block
Which one do I actually have?? Gen 3 or Gen 4?
Aluminum block, 5.3L, rear cam sensor, gen 4 rods, gen 4 head bolts, 24x crank.
Pics attached...
Old Sep 20, 2021 | 08:24 AM
Sodak66's Avatar
Gen III
Old Sep 20, 2021 | 08:42 AM
Originally Posted by Sodak66
Gen III
can you explain or are you guessing?
Old Sep 20, 2021 | 09:19 AM
psicko's Avatar
Pics attached...
If you're ordering head bolts, it's a Gen IV. If you're ordering a cam, crank, or knock sensors, it's a Gen III. If you just want to know what to call it so you can sleep better at night, it's a gen 3.5.
Old Sep 20, 2021 | 09:26 AM
I really need a definitive answer of 3 or 4 and the date code explained.
Reason being is Darton does not make sleeves for a Gen3 anymore (discontinued), but they do a Gen IV.
I can't tell what difference it would make when sleeving a block, but apparently something is different.
Old Sep 20, 2021 | 09:45 AM
Sodak66's Avatar
For that purpose its a Gen III block. No we are not guessing its very easy to tell from looking at it. A quick google search would give you all the info you need. good luck with your build.
Old Sep 20, 2021 | 10:17 AM
psicko's Avatar
Steve @ Race Engine Development would be the guy you need to talk to in that regard.
Old Sep 20, 2021 | 10:23 AM
The valley knock sensor location is the dead giveaway here. NO Gen IV's came that way. Gen III it is....
Old Sep 20, 2021 | 11:42 AM
RonSSNova's Avatar
That is an L33. 05-07
There was an LM4 alum engine from that era that was pure gen 3 with the longer head bolts. It was otherwise identical to its iron counterpart the LM7
GM did odd combos before switching to the Gen 4 in 2008 I believe.
