LS1 lifter tick noise?
It's more likely that a lifter collapsed, or your cam is wearing badly from improper heat treatment when it was manufactured.
IIRC - If you are going back with '98 heads you have to run the graphite/composite gaskets if they have the notch on the deck.
WS6 Store - 98 Head Gasket
If the heads are coming off, great time to upgrade...some 243's etc or CNC 243's or CNC 5.3's etc
https://www.summitracing.com/parts/NAL-12499217
Do you think the gasket will work lol... prolly not im assuming .. thx for the link for the 98s tho
And i didn't give him too hard of a time but i did make sure he learned to not do it ever again lol...
I'm just hoping i find sum wrong with the cam so im more confident putting em back together.
But there is NO WAY I could put the stock cam back in…. I mean… unless I was completely broke or something and just needed the car going. But I would have checked the rockers first also if that was the case.
It could possibly be a sticky lifter and since it’s already torn apart just throw a new set in and slap it back together.
