Mild Cam Recommendation
Old Jan 19, 2022 | 06:03 AM
  #41
z-maro's Avatar
I have the older version BTR stage 2. Pretty easy to drive with 3.42 gears. Some bucking crawling through a parking lot. Can lug it at 1200 rpm on the freeway.
The older version being the 227/234? Thanks for the input, that's about how I would describe the 226/230 that's in my car. My tuner is a distributor for BTR as well, so I have to take the recommendation with a grain of salt (same with everyone trying to sell you on their custom proprietary lobes).
The tuner also recommended a SD tune for this setup. After researching HPtuners a bit, it seems like an SD tune may be less time consuming since you would skip the whole MAF tuning step? Or would he end up spending the same amount of time to get the VE tables dialed in better than if doing a MAF tune?
Old Jan 19, 2022 | 06:10 AM
  #42
ddnspider's Avatar
Originally Posted by z-camaro
More back and forth, talked to my tuner today and he recommended a BTR stage 2 (227/238 .620"/.605" 113.5+2.5). Now it just happens that a good deal on a used one popped up. Any thoughts on that cam for our driveability goals? It has a good bit more duration than the others we were looking at. We don't want to sacrifice the street manners to save a few bucks.
We did also decide to do the oil pump, timing chain, and valve seals while we're in there.
Also most seem to be recommending dual springs, is there a major downfall to beehives that I'm missing?
That's not going to drive as nice as the others that were listed in this thread. Not that it would drive bad with good tuning, but it wont have the same idle/slow speed manners.
Old Jan 19, 2022 | 07:35 AM
  #43
z-maro's Avatar
Figured that would be the case. We'll pass then, looks like it might be sold anyways. $100 in the classifieds here.
Thanks to everyone that provided input! I'm sure I'll have a few more questions along the way. This will be our first time doing the cam swap with heads on, and doing valve springs and seals. The videos look easy enough, but everything is a pain on the back cylinders under the cowl.
