Mild Cam Recommendation
I’m looking to some of the LS1tech cam experts for cam recommendations for my fathers car. The car is 1999 Trans Am Firehawk (Dual/Dual catback) 6-speed, he will be keeping the stock rear gears. This is a 100% street car/cruiser, that will be lucky to see the track once. With that in mind the build will consist of the SLP bottom breathing ram air kit, SLP Blackwing lid, likely stock MAF if not the 85mm truck MAF, FAST 92/92, Kooks 1-7/8 LTs and ORY into the dual/dual catback. Plus the cam, springs, and pushrods and hopefully upgraded rocker bushings. The heads won’t be coming off.
His main goal is to have a good lope in the idle (probably can get that with most cams by lowering the idle speed), without sacrificing drivability. He is looking for good parking lot and cruising manners (no bucking or surging) with the stock 3.42 gears. Also would like good longevity from the valve springs.
Possible cam ideas:
WS6Store high lift hot cam (HLHC) 218/227-112+2
EPS 222/226-113
Cam Motion Titan 2 221/226-112
224R 224/224-112 or 114 LSA (probably lowest on the list being a dated single profile)
any other recommendations are welcome
He has his eyes on the HLHC and it looks like most that have that cam like it from reading the threads, but ones that don’t have it criticize the large split on the exhaust duration which may not be required for a car with LT’s.
I was leaning more towards the EPS 222/226-113. I almost chose this for my H/C/I build (AI 232cc heads, Mamo 102/102) but ended up going with the EPS 226/230-113. The 226/230 doesn’t have the greatest parking lot manners (might need the tune touched up) and I am thinking we would want to go a bit smaller for his car with stock heads/compression.
Not looking to set any dyno or track records, mainly looking for the muscle car sound but maximizing drivability and performance at the same time would be nice. So lets hear your thoughts, thanks in advance for your input!
I should also mention the desire to keep spring pressure low as to not put too much stress on the factory lifters. The car has about 35k miles.
The three most fun upgrades for a six speed fbody: gears, great shifter like Pro 5.0, MGW or Hurst and skip shift elimination.
FWIW - my back ground for making that comment is 20+ years with a six speed, LS bolton, LS1 heads & cam & LS strokers 3rd & 4th Gen fbodies, I've driven 700,000 miles in 3rd & 4th Gens 😀
SLP bottom breathing ram air kit, - totally worthless under 85 mph and marginal under 100 mph. Fast Toys made an extension that helps but Fast Toys set up is better.
SLP Blackwing lid - if you can find a good used FAST Toy's 98mm or 104mm lid that will seal, it's better.
stock MAF if not the 85mm truck MAF, - if using a Fast 92 why choke it with a stock MAF? 85mm MAF much better choice
FAST 92/92 - excellent choice! Nick Williams or WARR Performance (less expensive reuses stock TB sensors) make excellent TB's. Can be ported later if desired.
Kooks 1-7/8 LTs and ORY dual/dual catback. - Definitely a sweet exhaust set up!
The heads won’t be coming off - how many miles on the lifters? Even roller lifters develop wear patterns over time and miles. Low miles not as worrying.
He is looking for good parking lot and cruising manners (no bucking or surging) with the stock 3.42 gears. Gears improve drivability in otherwise bone stock six speed cars. 4.10's , Pto 5.0 skip shift were the best mod's my 99 T/A got better than heads & cam better than the 416 stroker motor. It's the single best mod for a six speed car. 3.73's also rock. Either gear gives the six speed car far better drivability and that's even more true with a cam.
Also would like good longevity from the valve springs. I'd go with the cam makers suggestion. I like BTR's Platinum Spring kit.
WS6Store high lift hot cam (HLHC) 218/227-112+2 - Definitely should deliver on the sound effects. My personal experience I'd want more intake duration. Intake can hit ~227 without drivability being compromised in a carefully planned package.
EPS 222/226-113 -Definitely Like EPS and this cam. Seems like an excellent choice.
Cam Motion Titan 2 221/226-112 -Definitely Like CM and this cam. Seems like an excellent choice.
224R 224/224-112 or 114 LSA (probably lowest on the list being a dated single profile) - old but still an excellent cam
The 114 will have good manners. Some road racers still like that fat mid range torque a good single pattern can lay down for coming off the corners. My old 224/224 XER on a 113 with TEA heads could do ~380 wtq at 3,700 rpm. It had a lot of advance can came on strong but was done at ~6,200 rpmHe has his eyes on the HLHC and it looks like most that have that cam like it from reading the threads, but ones that don’t have it criticize the large split on the exhaust duration which may not be required for a car with LT’s. Then that's what he should try. It leaves too much on the table for me.
I was leaning more towards the EPS 222/226-113. I almost chose this for my H/C/I build (AI 232cc heads, Mamo 102/102) but ended up going with the EPS 226/230-113. The 226/230 doesn’t have the greatest parking lot manners (might need the tune touched up) and I am thinking we would want to go a bit smaller for his car with stock heads/compression. Gears 3.73s or better 4.10's and your EPS 226/230 - 113 best cam for his set up in my opinion out of the ones you've mentioned.
Winner winner ! Gears 3.73s or 4.10's and EPS 226/230 - 113 that will make you smile! 😃😊
Thanks again for all the input, would you think the EPS 222/226 or Titan 2 would be better than the 226/230 for his goals IF staying with 3.42 gears?
One feels like, I just dropped $750 into a one arm bandit feeling putting gears in a 10-Bolt. Definitely understand when your dad's thoughts.
That's a very low mile car! Sounds very pristine.
Best of both worlds.
Humor - my 91 RS's 8.8 rear w/4.11's, had to have a pinion bearing after ~12,000 miles. Ironically, never had a 10-bolt need repairs that quickly. Probably Bad-Carma, all the bad but true things I've said about FORD for 30+ years. 😆 🤣 😂 😹
IIRC Cam Motion suggests 3.73's w/Titan 2 221/226 on a 112 in their requirements description. I won't second guess their suggestion would personally pass on this cam w/o gears - FWIW.
Being the EPS 222/226 is a 113, it might behave slightly better. I'd confirm with Geoff that it is happy with 3.42's before pulling the trigger on the parts cannon. He will have best information etc.
Apologies for mentioning ⚙ ⚙ again.
SWEET!!!
3.90's are A++
Good to hear, what rear gears are you running with it, and are you a M6? We don't intend to rev it out to 7k.
There is a Pro LS cam we think would be a good fit here. Check out our stage 3 truck cam SUM-8713R1. Specs on it are .550/.550/, 222/232, 112+5 with 3* of overlap. Similar to the Ghost cam but with .550" lift and the valve events are moved around. Designed around trucks but works well for folks with cars looking for power up to 6,500. With its 4* IVO at .050," it will have a nice steady lope to it. This will get along just fine with the stock gearing and M6. The 8713R1 will pull strong from 2,500-6,500 with budget-friendly LS6 springs. As an upgrade, you could go with the Trickflow by PAC TFS-16918-16 .600" lift beehives.
For an idea of the 8713R1's idle check out this video. Not our video nor our choice of thumbnail, but a nice idle clip video
When it comes to pushrods for the 8713R1 we typically see a 7.400" pushrod used. Things can vary, so we always recommend checking for pushrod length before purchasing pushrods. If you wanted to check for pushrod length and don't already have a pushrod length checker we offer the Trick Flow TFS-9501. When purchasing pushrods we recommend a minimum of a 5/16" Chromoly pushrod with a .080" wall. You can typically find a set of 16 for around $100. From there you can get into thicker wall and or larger diameter pushrods. We have our HDR thickwall pushrods. The 11/32" pushrods with a .120" wall have 25% less stress and 28% less deflection than a typical 5/16" .080" wall pushrod.
We know our customers like combos. All the Pro LS cams are available in a variety of combos. For all available 8713R1 combos look here. We like your plans of the FAST 92/92 along with the Kook's 1 7/8" headers and exhaust setup. Those mods will be a nice benefit no matter the cam you go with.
When I directly asked Lingenfelter Performance Engineering which size primary headers 1 3/4 vs 1 7/8 to use with a LPE GT2-3 cam (207/220 .571/.578 lift with 1.7 rocker 118.5 CL & GMPP LS6 heads), LPE recommended 1 7/8 primary.
One things for sure 1 3/4 or 1 7/8 both are light-years better than stock manifolds.
