What happened to this cam?
Old Dec 28, 2021 | 11:30 PM
rv12's Avatar
Default What happened to this cam?
I'm rebuilding an LS1 from a 2000 Z28. I was replacing the cam with a Summit stage 2 car cam. But when I pulled the cam out I saw this.
What caused this?
2nd question. I was planning on keeping my stock LS1 heads. Now that I have to take them off I want to upgrade to 243/799 heads. Would I do better with a summit stage 3 cam at this point? I can ask them about exchanging (It has not been installed yet)
At this point I'm pulling the heads and examining/changing the lifters and going to see what else in I see.
Old Dec 28, 2021 | 11:55 PM
How many miles on the engine, and was it serviced with good quality oil at decent intervals?
Old Dec 29, 2021 | 12:35 AM
rv12's Avatar
110k miles. Unknown history. I bought the car to swap the engine and trans into another car.
Old Dec 29, 2021 | 12:49 AM
Kawboom's Avatar
Brinelling, spalling, unless this thing has broken springs or failed lifters I wouldn't be surprised to find that the lifter guides on the wiped out lobes weren't holding them square.
Old Dec 29, 2021 | 06:42 AM
LaBLKv6Z's Avatar
Looks like the engine sat for a period of time, opened to the elements. That's some heavy corrosion and pitting on those lobes.
Old Dec 29, 2021 | 07:20 AM
Biebs's Avatar
engine abuse
Looks like condensation in the engine neglected service and stored at the bottom of a lake.
What does the rest of engine look like???
Old Dec 29, 2021 | 08:19 AM
stockA4's Avatar
I agree, that appears to be corrosion
Old Dec 29, 2021 | 10:27 AM
rv12's Avatar
I guess I'll be going through it at a higher level than I intended to. I'll let you all know what I find. It ran ok when I bought it. Shrug.
Old Dec 30, 2021 | 07:48 AM
Summitracing's Avatar
LS1Tech Sponsor
That cam gives us the feeling that this engine has lived a hard life and was put out to the pasture! Good call with diving deeper in now. You might spend more money upfront but could very well find other problems that you can fix before they cause an engine failure.
Dive in and see what all you'll have to replace. We'll have parts for you no matter how far you have to go with it. Regarding our stage 2 SUM-8707R1 cam. We would shelve thinking about a different cam until you get the engine apart and see what all else is needed. Then you could let the community know what the combo and goals are for this swap. It may end up the 8707R1 will be just right for you. If you needed to return it that isn't a problem as long as it's new and unused and within 90 days of the date of purchase.
We're always just a PM away if you wanted to contact us that way. We'll be happy to help!
__________________
800-230-3030
www.SummitRacing.com
Old Dec 30, 2021 | 07:25 PM
rv12's Avatar
I Dug into it... Some lifters show a little corrosion at 1 spot... Likely where it rested against the cam for a prolonged time. I need cam bearings. I'll replace the trays too, though they look fine. The knock sensors were a little rusty. There's definitely a little rust in the coolant.
What I think happened... The steam pipe leaked at some point (hard to diagnose since I've already replaced it). The corrosion areas are where water would have dripped down from atop the valley cover. There is minimal buildup on cylinder walls under the Pistons. Not too significant.
I'm guessing it got a little water in it and sat.
Old Dec 30, 2021 | 08:51 PM
Z28SteveA4's Avatar
Crank and rod bearing look ok? Or not diving that deep?
Old Dec 30, 2021 | 08:55 PM
Jimbo1367's Avatar
Be sure to use GM trays. Some people have had Chinese know offs floating around.
Old Dec 30, 2021 | 09:19 PM
rv12's Avatar
We talked about it and I'm just not sure we're diving that deep.. I'd love to take one loose and have a look but with torque to yield bolts... Yeah...
Old Dec 31, 2021 | 05:26 AM
Z28SteveA4's Avatar
Not a bad time to upgrade to arp rod bolts but not a must. Just to take a look so you are not wasting time or money. Just an idea though
Old Jan 2, 2022 | 05:53 PM
Wannabe Tech's Avatar
Default Lack of zinc
As a gm tech for 25yrs I notice in 2008 the camshafts and lifters started to fail. That's when our government set standards to remove the zinc in the oil. The zinc is required to keep the metal hard and prevent cam failure. I have replaced hundreds of camshaft and lifters since then. They are still failing in the newest of engines built today. The lobes start to pit and the rollers start to pit and the pieces will damage the lobes next to it as well. Need to break in the new cam with a zinc additive and add it to the engine once a year as a preventive maintenance.
Old Jan 3, 2022 | 09:20 AM
Stampede4ever's Avatar
Why one once a year for the zinc additive? And could you advise which additive to use, brand wise?
Thank you.
Old Jan 3, 2022 | 12:42 PM
Default Zinc Additive
Thank you.
Was told the zinc in the oil would insure the zinc was impregnated in the metal and would prevent future failure.. Remember zinc used to be in the oil till the government stepped in. You could add it to every oil change and it would hurt anything.
Old Jan 3, 2022 | 01:27 PM
Was told adding zinc to your oil on a regular basis would impregnate the metal with zinc and prevent cam failures. Now remember, zinc used to be a part of all of oils made until the government stepped in and removed it. It wouldn't hurt to add the additive on every oil change.
Old Jan 3, 2022 | 01:37 PM
Thank you.
Was told that adding zinc on a regular basis will impregnate the camshaft and rollers and prevent future camshaft failures. Now remember the oil companies had zinc in all the oil until the government stepped in and removed it. It wouldn't hurt to add it on every oil change.
Don't forget to clean the oil passages and pump. It will stick the pressure relief valve in the pump and starve the engine from oil pressure. Also the screen under the pressure sensor.
Old Jan 3, 2022 | 02:34 PM
99 Black Bird T/A's Avatar
Thank you.
I've never used any zinc additive.
164,000 miles on another LS1
195,000 miles on 4 cam V8 Tundra
256,000 miles on one LS1,
389,000 miles on a small block chevy
I think it's more about regular 5,000 mile oil changes using a good quality synthetic oil 🛢 and a high quality oil filter.
I have friends that will run their Gen IV 5.3 trucks low on oil, you know 15,000 + mile oil changes, truck is 3 quarts low on oil.
