Wipe pattern on yella terra with shims vs no shims
Hi guys I’m looking for some help here getting the correct wipe pattern on my 383. The first picture is with a shim from yella terra and the second one is without any shims. They seem to look very similar and I’m wondering which one looks better or if I should add more shims.
I personally do not see a problem with the first image as there's nothing wrong with the swipe being slightly closer to the intake manifold. That said if your looking to be closer to the center of the valve then I'd just do the one shim as two looks to be swiping the valve closer to the exhaust manifold.
Shooting for a THINNER wipe, regardless of it being centered or not, trumps a more centered but wider pattern. I’m not saying that a badly offset pattern is ok, but I shoot for as narrow a pattern as possible, and it being a tad high, or low on the tip, doesn’t scare me. Having said that, your 2nd pic looks better to me.
You can also look up darth_v8r write your he did a couple years ago on the setup of these rockers. It has a lot of good info in it. Also listen to chevelle he would know the best too
Are you using lifters converted to solid? If not your lifters are likely not pumped up which will change the results.
I used checking springs when I set mine up so as to not collapse the lifter.
One shim on my AFR’s got it right.
Without checking springs, you must use a pair of solid lifers. Hydraulic lifters will collapse and give you the wrong readings. You can take your hydraulic lifter apart and put a spacer in to make a solid checking lifter and then when you are done replace the parts of the lifter you removed.
