Ls9 lifters in LS1?
Old Jan 16, 2022 | 06:58 PM
RocketBird's Avatar
Default Ls9 lifters in LS1?
Johnson 2110 are $800 for a set & heard that LS7 lifters fail & not the way to go. Not looking to break the bank for a set of lifters… looking to spend anywhere from $150-500 for a good set that’ll last
in the future I’ll be running 125 shot of nitrous
setup
Torquer V2 Cam 113 LSA 232/234 600/600 lift
660 Dual Valve Springs
TSP Chromoly Pushrods 7.4 “Stock”
Rollmaster Timing Chain
36 Pound injectors (upgrading soon)
3000 stall
Speed engineering Longtubes with axle dumps
any ideas on lifter choice? I had so many ppl say LS7, LS9, Johnsons, etc also can i use my stock trays or go with something else & what’s the best head gaskets for a decent price bc I’m changing out my 241 for a set of stock 243s none ported bc ppl want to charge an arm & a leg for porting.
Old Jan 16, 2022 | 08:00 PM
AwesomeAuto's Avatar
I've had good luck with Summit lifters.
Old Jan 16, 2022 | 08:10 PM
RocketBird's Avatar
what type of summit lifter? LS7, LS9 etc?
Old Jan 16, 2022 | 08:21 PM
Either work quite well.
Old Jan 17, 2022 | 03:47 AM
The LS7 ones. I don't have any complaints with them yet. I swapped to them because both the ebay no-name ones that i used to be able to rely on and the Crane ones I bought in a pinch were either collapsing (ebay) or causing lots of valvetrain chatter (crane). Swapping to the Summit ones instantly fixed it and they were very affordable. Its been a couple of years and that setup is still together with no issues to report.
Old Jan 17, 2022 | 09:25 AM
SAPPER's Avatar
https://cammotion.com/lifters/oem-qu...elphi12499225/
Old Jan 17, 2022 | 10:17 AM
wannafbody's Avatar
Morel has a good reputation, somewhere in the $200 range.
Old Jan 17, 2022 | 11:02 AM
stockA4's Avatar
Stock high mileage lifters should be fine I'd try them with that setup. The aluminum block wears out the lifter bores though, so be wary of that, I wonder if that could be exacerbated with higher spring pressure + RPM
Old Jan 20, 2022 | 10:09 AM
Summitracing's Avatar
LS1Tech Sponsor
OP,
As AwesomeAuto and wannafbody pointed out our LS7 lifters or Morel lifters are good options. Our LS7 lifters are part number SUM-HT215-16 and the Morel 7717's are part number SUM-HT217-16. It would be a good idea to go ahead and replace the lifter trays as well. We have those in our own brand as part number SUM-150132-4. You can buy the LS7 lifters and trays as kit part number SUM-HTLSKIT2. The Morel lifters aren't yet available in a kit with trays but they would use the same SUM-150132-4 trays.
__________________
800-230-3030
www.SummitRacing.com
Old Jan 20, 2022 | 10:31 AM
Bob570's Avatar
Luckily the Torquer V2 has pretty gentle lobes. Out of the options listed here I would probably go with the Morels.
Make sure you replace the lifter trays too.
Old Jan 20, 2022 | 11:11 AM
stockA4's Avatar
Out of all that the only thing I heard was "You can use a tape measure if you want" haha 🤣
Cul8er ? What happened to your big block video?
Old Jan 20, 2022 | 11:49 AM
In the right thread??
Old Jan 20, 2022 | 12:33 PM
RocketBird's Avatar
Originally Posted by Summitracing
OP,
thank you!
Old Jan 22, 2022 | 04:48 AM
Jimbo1367's Avatar
are they quite? I wonder how many lifters get blamed for noise when it’s more of the cam’s aggressive ramps VS. how many cams get blamed when it’s the lifters fault.
Old Jan 22, 2022 | 06:15 AM
They were a lot quieter than the no-name (claimed to be OEM) and Crane lifters I was using before.
Old Jan 26, 2022 | 08:37 PM
RocketBird's Avatar
OP,
awesome thanks summit racing! Also what upgraded gasket should i go with? I have Chromoly pushrods there 7.4 stock height from texas speed can i use those for a ls7 gasket etc?
Old Jan 26, 2022 | 08:49 PM
02*C5's Avatar
I myself like short travel lifters. They do have a noice to them but you get the lift capability of a solid lifter with the convenience of a hydrolic lifter. The tolerances are a bit tighter but well worth the money.
Old Jan 28, 2022 | 10:21 AM
LS1Tech Sponsor
For factory .051" head gaskets you'd want the GM NAL-12498544 LS1/LS6 MLS head gaskets. For a nice compression bump and to reduce quench you could go with the .045" Trickflow by Cometic MLS TFS-30694030-045. With .045" head gaskets and 65cc 243 heads, you would be right around 10.7:1 compression with .041" quench. With the .051" head gaskets and 243 heads, you would be right around 10.5:1 compression with .046" quench. Bumping the compression up will improve power/torque across the range. Reducing the quench distance will help improve a more efficient combustion cycle and reduce the chance of knock.
__________________
800-230-3030
Old Jan 28, 2022 | 12:03 PM
If I may butt in- Is there an "ideal" quench number (gasket thickness) for all bore/stroke combos, or does it hinge on a particular stat like compression ratio, bore size, or other factor?
Learning process is on-going....
Old Jan 28, 2022 | 12:37 PM
LS1Tech Sponsor
No problem G. That's a very good question. There are recommended quench ranges. Those are basically set by connecting rod type (steel/aluminum) and RPM range. Check out this article in our help center about quench and the recommended ranges.
__________________
800-230-3030
