First start up - running very rough and backfiring
Do you guys think the old tune that was done for this exact setup but with a stock cam is the problem?
Any suggestions guys? Thx.
Car is an 04 C5 btw.
double and triple checked full spark plug and coil engagement?it sounds like a spark / timing issue. even if the tuning was remotely close it wouldn't backfire right?
Thanks!Trending Topics
Guess the Stage 3 blower cam I put in really made it act up.Anyways that was the problem
Now to button things up, break the clutch in and then off to the tuner once this weather is back to "normal".Last edited by momofx; Feb 2, 2022 at 01:40 AM.
in Pompano Beach, FL) installed it correctly but I should have known better as I found lots of other things done very sloppy and dangerous to say the least ie. live wire from battery to starter was damn near fried due to being so close by header, knock sensor wire burnt and cut on one side, etc. etc.
Yeah I don't like having constant power down to the starter. Ford did it right by having a starter solenoid on the firewall and that's how both of my Camaros will be when I'm finished. Much easier to connect a remote starter switch for setting valves and performing compression tests.
My daughter ran into trouble with her truck acting up and she described smelling wires burning. After shaking the power wire and seeing sparks from below I was able to determine where her problem was and why she was eventually leaking engine oil. Apparantly the previous owner had changed the starter at some point but forgot to bolt the power wire back down to the frame which eventually led to the wiring melting a hole in the dipstick tube about 6-8 inches up from where it inserts into the block.
