6.0L Iron Block GenIII vs GenIV !?
Ok, before everyone tells me to search, (I did, trust me) hear me out.
I know about the differences between GenIII and GenIV; 24/58, AFM, DOD, VVT, Cathedral Port vs Rec Port, Cam Sensor Placement, Different Rods, DBC, DBW, Different Valley Cover Bolts, etc, etc engine codes, LY6, LQ4, LQ9, this place is supremely rad and has taught me all about those things.
I can even tell you that the Gen III 6.0L Iron Block LQ4/LQ9 is GM #19369841, and Gen IV 6.0L Iron Block LY6 is GM #12679002
But, what I can't figure out is if there is anything else different about them to justify spending the extra $ to buy the GenIII bare block vs GenIV bare block? Do a search for (GenIV) 19369841 and you'll see they're around $1,300 - $1,400. Do a search for (Gen III) 12679002 and they're almost $2,000. (SDPC has one with billet caps for a what looks like a good deal)
If you wanted to stay with iron block, and literally build whatever version of it you wanted, you know, hit it with ALL the right stuff. Is there any benefit to one block over the other?
Literally every thread I searched and read just devolved into people explaining the non block related differenced based on finding one in a junkyard which is great for everyone learning the basic differences of the associated parts, but I can't really find anything (obvious) about what makes the blocks any different for making power to try and explain the price difference or anything else major.
thx guys,
thx guys,
Depends on where you want your cam and knock sensors...
The following users liked this post:
G Atsma (02-09-2022)
For $1,400 bucks, buying a brand new one and having it shipped to my work for free is a helluva lot easier than having to deal with any of the terrible junkyards around here or local craigslist (which is garbage for engine parts here in Western Washington), any of which may or may not have any idea what to look for, won't know how to send me pictures of what I want to see, take days to get back to you, or have zero information on them when you finally do get a hold of them.
I don't need or want any of the parts that would come with a junkyard motor, and I don't want to have to deal with throwing it all away, or again, trying to part it out dealing with the craigslist people who never get back to you, or flake on you after three emails.
It's all going together with brand new aftermarket parts, so starting brand new is by far the easiest way to guarantee success. Just trying to figure out if there are any actual important differences between the 6.0 blocks other than Cam and Knock sensor holes, and if not, great, question answered.
Tyler Dietzenbach (02-10-2022)
theunderlord (02-09-2022)
Totally with you on that one brother.
The following 2 users liked this post by Ls7colorado:
02*C5 (02-10-2022), Homer_Simpson (02-11-2022)
The following 2 users liked this post by 02*C5:
G Atsma (02-10-2022), Homer_Simpson (02-11-2022)
Just because it turns over doesn't mean its good. Do as much checking as you can.
My 6.0 spun..... Spun a main bearing lol
Had a machine shop machine the block and install new cam bearings. Motor got hot at some point and needed .030" decked.
Bought the long block for $300 and had probably $1200 in machine work on the block.
Then I am the .01%. The complete engine I bought had eaten its front main bearings but still spun free and made compression. Deep scars in the crank, it was probably a mile from spinning the bearings when the PO turned it off and put it up for sale.
Anyways, if it eat into the crank why would that make the block trash??
This is why I asked if the "NEW" blocks are already machined and ready to be assembled because if not then even a 6.0 that has a bad bearing or 3 will be no different once machine work has been done.....
The following 3 users liked this post by Ls7colorado:
The following 2 users liked this post by AwesomeAuto:
Homer_Simpson (02-11-2022), theunderlord (02-10-2022)
I can even tell you that the Gen III 6.0L Iron Block LY6 is GM #19369841, and Gen IV 6.0L Iron Block LQ4/LQ9 is GM #12679002
thx guys,
thx guys,
G Atsma (02-11-2022)
The following 3 users liked this post by theunderlord:
