LS1 cam/heads advice
My buddy is running an '01 auto TA wihtout a stall converter yet and he has a ton of suspension mods and Pacesetter LT on the car so now he is turning his attention to a heads/cam setup. He won't be tracking the car it'll be for on the street. Have ideas or options changed over the years on what's great for street use and DD? He wants some idle chop but not a total sewing machine effect. I know alot of folks told me to go at least 228 if I was thinking 224 since it wasn't that much of a jump. Also I had a manual he has an auto I think people made different decisions based on that as well especially if he eventually gets a stall added. What is the advice in 2022 for an A4 for heads and cam with and without a stall that's not overly aggressive for the street? Any and ALL opinions are welcome please. Also which manufactorers products would you use and what's the general advice on getting a stall is it still considered a slam dunk mod for an A4 and how would that change your heads/cam choice? THANK YOU!
Single best mod for an A4 Fbody remains a quality aftermarket stall converter like Vigilante, Yank or Circle D etc.
I'd suggest he skip the heads & cam completely if keeping the stock converter and get the car dyno tuned. The tuner should be able to adjust the tune and lower the idle so it "sounds" cam'd and has some lope.
Since you liked the Racing Racing TR-224 cam, I suggest talking with Geoff of TR frame at Engine Power Systems aka EPS. He has a sweet 226/230 cam that will drive very similar to former TR-224 but make more power. The EPS 226/234 is also very sweet. Set of Trick Flow heads w/92mm intake manifold and ~450+whp A4 to 470+ whp M6 is very possible with out busting the bank.
Less expensive heads, I'd look at TEA's and TSP or if you're friend likes waiting with poor to zero communication AI.
Have two M6 LS w/strokers etc & an A4 w/bolt on's. Plan is for the A4 is Vigilant 3,200 stall, EPS 226/230 cam my M6 T/A's old TEA S2 5.3 heads. I wanted the EPS 226/234 but P to V will be an issue with my ancient 20 year old heads.
I've only ever messed with manual cars, so I really don't know much about autos, hopefully other members will chime in. Black Bird is pretty knowledgeable,
Your old combo is still pretty good. Everyone has a different idea of what does and doesn't make a good driving car, I tend to be more ok with larger cams than most. That said, Black bird's suggestion of heads cam paired with a Fast intake will make a pretty damn good power and still drive very nicely if the tuner is even remotely competent.
My opinion, that sort of build is a mismatched mistake, nothing more nothing less.
If he'll do a quality stall, he'll have a fantastic basis to build on.
There's definitely still folks on the forum with a wealth of practical hands on experience.
Your right about how well these car's respond to the badic mod's. I'm happy yor helping you friend with good advice on suspension set up. The factory deal is OK but the factory shocks...SUCK. Those improvements just made for a better all around car that's even more fun.
BTW loved the magnesium Z06's on your T/A! The GT500 & 19 Bullet are pretty sweet as well.
