1.8 rocker arms
I had a 95 z28 lt1 one time that the previous owner had crane gold rocker arms on an otherwise completely stock lt1 engine that ran good and added .010 lift to the stock cam but a couple rocker arms did wear the roller tips grooved into the side of the aluminum rocker arms.
Ive since sold that car or had to part it out in 2014 and never got around to putting it together but was wondering what rocker arm upgrades they have as i havent been active with ls1 since 2013-2012 and seen they have bronze bushing. I just seen they have the 1.8 ratio vs the stock 1.7 when i looked it changed my .575 lift cam to .607 not sure if it makes much difference but with a good set of heads the test flow numbers and .550 .600 lift which are slightly different. Stock 853s flow around 230cfm at .600 and 243s 260cfm stock unported a pair of 853s ported flowed as much as a stock set of 243s from what i read that is with stock valves. Looking into refurbished or reman 243s on ebay but im currently tied up with 700$ in front c7 z06 wheels and tires. I shouldve did an underdrive pulley for the extra 10hp when i did the cam but was changing the corvette balancer and cam on a budget as they've been know to walk off stock ac delcos.
So for 1.7 to 1.8 rocker arm change, probably ~5 whp to 12 whp given or take a little.
One thing about the Pro Magnums is that the trunions are huge and set up in such a way that they'd never allow roller bearings to spew all over the engine and the roller tips reduce valve train friction. They are much more durable than aluminum rockers since they are steel and they are not much heavier at the tip than stock rockers and lighter at the tip than aluminum rockers.
If I recall correctly the LS2 cam gives a .525 lift, with 1.8 rockers that goes up to .556. Those are not very radical lift numbers so the improvements possible with a bigger cam would likely be more dramatic.
