Rocker bolt washer/spacer
Those fasteners will pull the aluminum threads out the head before you stretch them.
If pushrods length was set correctly and engine ran correctly for years, they don't need to be re-adjusted.
If you have any new valvetrain noise not present before, it could be a lifter going bad (discharging too quick?) and cause loose rocker or if you over revved your engine, maybe bent pushrod.
