What size valve springs
However, you could just use a set of factory LS3 valve springs being at .550 lift, provided that you are using factory rockers. TSP's description of that cam even says that it is designed to use factory LS6/LS3 valve springs.
These are them, they say .570 lift on here.
https://www.summitracing.com/parts/nal-12499224
Saw enough brand new stock LS1's have valve float at the end of the dyno runs back in the day to always spend a little more for high quality valve spring like PAC.
YMMV
YMMV
This is why I run a .630 spring with my .629 lift. It doesn't make much sense to run a .660 spring because I am just unnecessarily further from coil bicoi
