Cam suggestions for 383 LS1
Here's where things get murky. We built this engine in 2006 with a set of used 317 heads from a speedshop out of Florida that were "welded", cnc ported, polished, and milled to a static chamber volume of 50ccs(supposedly). The first time we ran these heads (2005) with a 224/232 112lsa cam, we didn't have enough PTV clearance, which broke some ringlands and necessitated a rebuild, hence the 3.905 and stroker kit. Ferrea 2.055int, 1.6exh stainless valves. The porting looks decent but as far as flow numbers or port volume I have no idea. There's some stampings on it from the machine shop that built the heads, but nothing comes up in the search function. Best I can tell it's a work order number with CNC-T stamped on both of them. The heads will be coming off the car to check deck clearance to see why my machine shop threw a set of .060" graphite headgaskets on it (Shop labelled DC as .007, as in .007 in the hole). The SC is either 11.8:1 OR 12.4:1 depending on deck clearance measurement being above the deck or in the hole.
I have a set of mint, low mile 243 casting heads that I can send off to TSP or FED or TEA depending on what the budget looks like after the holidays.
Anyway, I've been recommended:
Cam Motion Hot Street Stroker 239/247 .621/.604 113 +3
BTR Custom grind 235/250 .629/.629 112.5LSA
And the cams I've arbitrarily picked by skimming a catalog are:
TSP torquer v4
TSP BFD 5.7
TSP Stroker 244/248
I'll also be replacing the lifters while the heads are off, they are EGW stock replacements and I'm pretty sure they won't live long with these high lift high duration cams. If anyone has a recommendation there, I'd appreciate it.
So, option A would be to use the 317 mystery meat heads after CC'ing the chambers, runners and possibly getting someone to benchflow them and pair a recommended cam with it.
Or option B, send the 243 heads off for a full cnc port and valve job and spec a cam to it and have lower static compression (11:1) with a matching cam using good, valid flow data and known good engine combinations.
I'd be thrilled with 450rwhp, but more is always more and ofc better. Strictly a weekend car that might go back to the track once or twice a year when it's done.
What say you?
Last edited by IronHammer86; Nov 11, 2022 at 09:53 AM. Reason: Spacing for readability.
1) Replace the 1 5/8 Long tube headers and go with a least 1 3/4 primary Long tube headers. I run 1 7/8 on my 383 LS1 stroker
2) Ask whomever ports the heads to recommend a custom matched cam for best results. Sounds like you're considering excellent head porters. I'd add Mamo Motorsports to the list if you can consider aftermarket heads as Tony is top notch. He can set you for a 500whp+ 383 LS1
3) Consider getting the Fast 90 & 90mm TB ported. If you go for 500 whp, sell the 90mm Fast and get Tony to port a new Fast 102 intake and 102 TB for your car.
I don't want to ditch the fast 90 just yet since I just bought the NW90 TB to get rid of the paperweight Fast 90TB, that thing was downright dangerous. Maybe i can catch a 102 on sale somewhere.
I'll see what cam the shop I pick recommends and go that direction, do you think it's worth the time to send out the 317s to get any data out of them or should I just sell them as is? I hate wasting good parts, but it just won't work on my short block due to several issues.
As for cam, some in 235-237 intake duration would work nicely. LSA would depend on driveability and if NOS might be used. I'd go a 113 LSA.
1 7/8 headers definitely.
Port and smooth out any rough edges in Fast 90 yourself with sanding rolls and drill.
Good luck with your build.
.040 quench. You cluld go tighter but you need to be dead on for measurements and know exactly what you got. And a 50cc 317 sounds like trouble to me. That's a lot of material removed. I would verify that as well and ask some shops here If that's even ok. Too much milling can cause big problems.
i'll save you the trouble, but long story short he runs the comp 54-459-11 in a 383 iron stroker (5.3 bored/stroked)
if i recall, that build had TEA ported 243s and a fast 102.
any head milled that much will have trouble sealing up the intake.
the fast 90 will work, but yes get in there and smooth up the rough edges. wouldn’t go further than this if you don’t know what you are doing though.
cam is subjective, but I’d shoot for a hair smaller on a 383 than you were looking at.
a borescope thru a plug hole should let you get a look at the piston height.
Thanks for all the suggestions so far, Bobby at Cam motion is now recommending the Titan V, 232/238 113lsa+4 with the 243 heads using FED's flow numbers and a slight mill to achieve 11:1 SCR. I need to call FED and ask them a couple questions, but I'm pretty set on them, their midlift numbers rival some very high-end aftermarket heads that aren't going to be available for quite some time.
I run this comp cam with AI ported 243 heads in my 403" LS2. I'm happy with it, its extremely torquey from 3600rpm in my setup. (11.8 static comp, works out to around 8.5-8.7 DCR, I Think. I run 92 and have no issues) I pull to about 6800-7000 rpm. I run a FAST 102 and a 102 TB, and 1-7/8 headers.
