Yella terra shimming
Black is no shim
green is 1 shim
red is 2
I forgot to take pictures with 3, but it looked off to me anyways. I can do it again if necessary
I rocked the rocker arm close to bottoming out with the checker spring. I didn't have any way to measure the lift and I'm running a high lift cam anyways (6.12 at the valve).
If my thinking is correct, I could use a pushrod checker to also open the valve and checker spring with the cam and head installed and fiddle around until I find the right shim and pushrod length. I just hope the pushrod length checker doesn't snap, but I can open those calves with my finger with that checker spring on.
I have a dial indicator, but I've never been smooth in using one. But I checked the geometry as best as I could measuring the lift trying to keep it exactly at .612(at the valve). I went a little over once (about .65). This is what it looked like. I used the intake valve to check the geometry which is on the left.
Left (intake valve)
Left (intake valve)
Left (intake valve)
