Camshaft help
Old Jun 14, 2023 | 04:56 PM
tom70's Avatar
Default Camshaft help
I have a three bolt cam with 4519 S 046059 on the rear of the cam. Anyone have any info on this cam?
Old Jun 14, 2023 | 05:12 PM
Originally Posted by tom70
I have a three BOLT cam with 4519 S 046059 on the rear of the cam. Anyone have any info on this cam?
Fixed it....
Old Jun 14, 2023 | 05:14 PM
02*C5's Avatar
Originally Posted by G Atsma
Fixed it....
yes you did 🤔😂
Old Jun 14, 2023 | 05:16 PM
02*C5's Avatar
That’s a stock LS2 cam
Old Jun 14, 2023 | 08:21 PM
tom70's Avatar
Sorry I fat fingered my phone 🤣 thanks for the answer. Would that work in a 5.3?
Old Jun 14, 2023 | 11:20 PM
Quite nicely....
Old Jun 14, 2023 | 11:30 PM
02*C5's Avatar
Yes but what are your final goals?
Old Jun 15, 2023 | 06:05 AM
tom70's Avatar
In a demolition derby car. With a 4l60e transmission and 4.88 rear. Mostly 2500-7000
Old Jun 15, 2023 | 09:27 AM
So this is short term. The car's getting wrecked on purpose. Why bother building an engine for it?
Old Jun 15, 2023 | 02:20 PM
tom70's Avatar
unfortunately it's not just about wrecking a car on purpose anymore. you have to have enough power to push someone out of your way or get out of the way of a bad hit. where this car is ran almost everyone else has a built engine.
Old Jun 15, 2023 | 04:02 PM
A stock 6.2 truck engine will do that. There are far more of those sold in trucks than all cars put together.
Old Jun 15, 2023 | 04:11 PM
02*C5's Avatar
well you’ll need a cam that gives you power down low so the cams that have been recommended would be the best. The 228R runs from 1.8-6.8K rpm’s peaking at about 6.2K rpm’s and holds the power all the way through 6.8K rpm’s. I don’t have the specifics of the smaller cam and I’m sure @G Atsma can give you that power curve and you can make a decision.
Old Jun 15, 2023 | 06:25 PM
68Formula's Avatar
If you want to push stuff you need low and mid-range torque. So if you're going to toss that LS2 cam in, I'd advance it 4 degrees. But then you're spending money on an adjustable gear to band-aide not having the right camshaft in it.
The SDPC Hot Truck Torque would be the better choice, low budget, and still push past 6k. Way more torque in the 2500-5000rpm with maybe giving up a few hp above that.
