2nd Piston Ring gap smaller than top?
Summit link: https://www.summitracing.com/parts/HSN-2M5170
Are you sure you don't have the 1st and 2nd rings switched? The top ring should have a slightly silver finish to it, that's the molybdenum plating. Second ring is usually a dull grey cast iron finish.
This makes me wonder, because I have a set of Hastings rings for a build I'm going to do soon.
AT Bore 4.00" = 2M5170
Top = .020" - .030"
2nd = .018" - .028"
Oil = .015" - .055"
The gaps my rings came with are within that, but now my question is more if my top ring gap should be larger or smaller than my second? From everything I have read, the bottoms should be about 0.02 LARGER than the top. BUT after asking this, Hastings said: "For Hypereutectic piston applications, the end gaps of the Top rings are higher than the 2nd rings in general. This is to give extra room for ring expansion with the extra heat produced in the engine with hypereutectic pistons."
Unless I am mistaken, my 2007 Lq4 comes with Hypereutectic Cast Aluminum Alloy pistons from the factory. So is this what I should follow?? If so, do I follow the same 0.02 rule? meaning I would gap the 2nd rings about 0.02 SMALLER than the top rings?
Thanks again for any info or guidance.
Top = .020" - .030"
2nd = .018" - .028"
Oil = .015" - .055"
