MTI sent us the wrong cam??? Please MTI respond!!
We were not aware of this problem until the members of LS1Tech brought it to our attention by looking closely at their cam cards and for that I'd like to extend my sincere appreciation and also apologize for the mistake.
These have been sent back to Lunati this morning and replacement cams are on the way to us.
Predator-Z: If you'd like to keep the cam that you have and install it as Colonel suggested, please e-mail me and let me know and we can work out the details.
If you'd like me to send you the corrected grind, I'm more than happy to and the shipping to you will be taken care of as will the return shipping on the other cam - just let me know and I'll get it handled.
2xLs1 - Same offer of course. Please let me know which way you'd like to go and I'll work with you to ensure your complete satisfaction.
Unfortunately in business, errors do occur and I'd like to apologize again for this mistake. It certainly wasn't intentional and now that we're aware of it, we're going to make it right and stand behind our product - no questions asked as that's the only way to handle it.
Please call or e-mail me directly davidc@motorsporttech.com if you have any questions or concerns and I'll get back to you asap.
We greatly appreciate the support of this forum and its members and appreciate you making us aware of the above and giving us the opportunity to correct this and demonstrate our comittment to your complete satisfaction.
Sincerely,
David Coates
MTI
To add another little kicker to this, when my customer dropped off his parts and his car, he told me the the person at MTI he talked to when he ordered the parts told him to tell his installer to be sure and install the cam 4* advanced. I personally called MTI the day I was doing the install and asked them about this. Whoever answered the phone that morning just laughed when I asked if I needed an adjustable timing chain and said to just install it dot to dot that the 4* advance was ground into the cam.
Dan
Dan
Generally, I don't think that you can ask a vendor to pay for consequential damages. If the vendor was paid to do the install (package deal) then they are responsible for labor and shop supplies. Otherwise, offering prompt replacement, including shipping, is a good response.
I can see in your case that you identified the problem before installing the cam; contacted MTI and they gave you the go ahead. Maybe in this case they'll do something, since the extra labor could have been avoided had the person you dealt with at MTI been more knowledgable.
It lopes pretty good and seems to peak up high . . .
And if you read my post carefully, the MTI Rep told my customer to be sure and install it 4* advanced. The MTI Rep told me the 4* was ground into the cam. I didn't identify any problem. I was calling to verify what the Rep told my customer. I was not aware at the time the cam specs were with no advance.
Yeah good point. . . its going on the dyno this saturday so If the numbers suck ill yank it out for something bigger and have it checked. Its always loped pretty good and it peaks way high and doesnt have alot down low so Im thinking it may have 0* of advance.
I think that it should idle smoother straight up than +4. The more you advance it, the more time the intake valve is open with the piston not yet going down on the intake stroke (so more exhaust charge pushes back through the intake valve.)
At what RPM does yours peak? Mine peaks at 5900 but holds about that to around 6400, FWIW.
Just remember that the stock timing chain retards the cam by 1-2 deg. anyway with the slack.
