Big Cathedral Ports
Mike Lough uses the Brodix BR1-13's on some of his builds and HED just put those MAST 295's on Leroy's 388. Brought it it down from 427 to get more RPM, as in 9000rpm if need be.
Looking at port size, intake/exhaust valves, and valve angle
Brodix 245cc - 2.10/1.60 (13.5 degree valve angle)
FED 265cc - 2.13/1.61 (10 degree valve angle and also uses a LS7 rocker)
MAST 295cc - 2.25/1.60 (12 degree valve angle)
OP, maybe give HED a call and discuss those MAST heads for NA, I'd be hard pressed to say that you wouldn't pick up some more power over your PRC's. Probably would be time to start thinking about a porting your MSD too.
I seen something about a motor making 615 tire with some 275cc cathedral deals years ago... I think I'd need to see 40-50 more to justify the 6k plus im seeing.
