5.3 piston ring help
Old Oct 10, 2023 | 02:44 PM
taylor74b's Avatar
Default 5.3 piston ring help
This is my first time to do piston rings ( done them in dirt bikes, but they come ready to install).
I have a gen 3 5.3, bored .30 over. What should my top and bottom ring gap be?
thanks.
Old Oct 10, 2023 | 03:28 PM
01CamaroSSTx's Avatar
I'm sure you meant .030 over but ring gap depends on what your plans are for the motor. NA, NOS, forced induction.
Old Oct 10, 2023 | 04:01 PM
RB04Av's Avatar
Same basic rules apply to pretty much ALL motors.
N/A, .004 - .0045" per bore inch, on the top ring; .0005" more than that on the 2nd. So for a 5.3, .019 - .022" or so on the top, .022 - .025 or thereabouts on the 2nd.
Boost/nitrous, add about .001" per bore inch to that.
Always better to have slightly too much (heavy emphasis on "slightly") than ANY too little. A bit too much, you get some unnoticeable extra blowby; too little, ANY too little, even .0001", you get INSTANT CATASTROPHIC DESTRUCTION. Since nothing about that sort of thing is ever "perfect", pretty obvious which side you want to tilt your errors toward.
Old Oct 10, 2023 | 04:13 PM
taylor74b's Avatar
just a stock rebuild.
Old Oct 10, 2023 | 04:58 PM
I’d set it up at .018 top and .020 second ring if I were building it, for a stock rebuild.
Old Oct 10, 2023 | 05:02 PM
taylor74b's Avatar
thank you, for taking the time to reply. It’s much appreciated
Old Oct 11, 2023 | 09:44 AM
As an example my LS370 NOS build is close to 13:1 compression and I went with .026 and .028 ring gap.
.0065 x 4.03=.026
.0069 x 4.03=.028
Old Oct 13, 2023 | 09:12 PM
1FastBrick's Avatar
What brand pistons did you use?
For Example UEM Silv-O-Lite have specific recommendations. I forget what the Speed Pro say...
Old Oct 13, 2023 | 10:15 PM
Very interesting. I’ve never seen this info before, and never had any of my builder friends talk about this ether. I’ll admit that I do mostly forged or billet piston builds but still…
Old Oct 13, 2023 | 10:25 PM
1FastBrick's Avatar
I have used a few set's so I thought I would mention it.
I used the Speed Pro's too But I will have to look for the sheet that comes with them as I can't recall if they had any thing like this. I also was unable to find anything specific on line for them.
Here is the Silvolite instructions. Can't attach the PDF for some reason. https://uemimages.blob.core.windows....IL_Instruc.pdf
Old Oct 14, 2023 | 08:57 AM
taylor74b's Avatar
I did use sil-o-lite. At 0.030 over i gapped them at 0.020 and bottom ring at 0.024mm. Should I be fine?
Old Oct 14, 2023 | 12:19 PM
I’m not sure why they are asking this to be done. In all of our testing, we found that a smaller second ring gap caused the second ring to flutter, and the engine lost power. All of that testing involved forged pistons, which have more piston to wall clearance than a hypereutectic piston. This means that the forged pistons top ring will see more heat than the hypereutectic pistons top ring, at least until the assembly gets up to operating temp. I could see opening up the top ring gap in a setup where the top ring was higher than normal, toward the crown, which will see more heat, but I’d still want the second ring gap larger than the top ring. I’m absolutely not opposed to learning something here, that’s for sure. I’ve built 4 hypereutectic builds in the past few years and I set them up .018/.020 top rings, with larger second ring gap. I did one turbo build this year that was hypereutectic and was way out at almost .030, with larger second ring gap. I always make sure I’ve got enough oil pump in a build to keep oil temps in check, which keeps piston crowns and cylinder walls cooler…which keeps rings cooler as well.
1FastBrick, what’s your take on this deal? Anyone else got pertinent info or data on this subject?
Old Oct 14, 2023 | 12:20 PM
You are good to go with those numbers.
Old Oct 14, 2023 | 10:32 PM
1FastBrick's Avatar
So It could be that there is more expansion in the aftermarket Hypereutectic piston or that the top of the piston is either exposing more of the ring to heat or that the ring land is higher than factory. I am not 100% sure for there exact reasoning for the additional gap but they did put the disclaimer in there for a reason!!!
Here is a small article you may find interesting on the subject.
https://www.enginelabs.com/news/what...ctic-ring-gap/
FYI, I am building a Diesel engine right now with Mahle Motorsports Race cast pistons and Mahle call's for Bore X 0.006 for Top Ring and Bore X 0.0055 Second Ring...
https://www.us.mahle.com/media/usa/m...ructions-2.pdf
Old Oct 14, 2023 | 11:32 PM
I totally get opening the top ring up if the top ring has been moved up toward the crown. I just haven’t came across any eutectics that have the top ring moved up…not yet. The Mahle info you posted is stating that it’s current tech to open the second ring up larger than the top…but I’ve been doing that since I started cutting rings over 30 years ago.
I think I’ll call my machinist Monday and chat about this. He works for Gibbs as a consultant now. They spend over a million a year with JE. He will get me up to speed on this larger top gap.
Old Oct 14, 2023 | 11:36 PM
1FastBrick's Avatar
Right On! I know it goes against what we were all taught but they must have a reason. I am still trying to figure it out myself.
Old Oct 15, 2023 | 01:56 PM
What has my thought process wondering here, is that eutectic (high silicone content) material doesn’t grow nearly as much as a non-eutectic aluminum piston. Therefore it allows you to set the eutectic and especially hypereutectic pistons up with a tighter wall clearance. A tighter clearance shields the top ring more, keeping the top ring temp lower than with a forged piston setup…at least until the assembly gets up to full temp. Ok, I’m rambling…I’m looking forward to learning here.
Old Oct 15, 2023 | 02:03 PM
1FastBrick's Avatar
I totally understand what your saying. But I know they have changed the formulations a little bit too. I am curious to see what your contacts have to say about it as well.
Old Oct 15, 2023 | 02:19 PM
1FastBrick's Avatar
I know I have the box some where for the speed pro, but not sure if it has the paperwork in it. I am curious if they have the same recommendation.
Here is the Mahle kit that comes with the pistons for the diesel I am working on.
Old Oct 16, 2023 | 10:38 PM
chrisfrost's Avatar
Default Silicon content
Hello people I know that when I was building a 5.3L about 15 years ago that the Speed-Pros had right around 17% silicon and the Mahles had in the 12% silicon range . I imagine this would also make some difference not sure what but maybe this info will help . Good luck
