The wait is over...Stage 3 AFR Details inside
I'll stick with my AS heads.....
Good job on getting those numbers.....
Who is going the fastest? The person that spent the most money in the right places.
The power for any motor is in the cylinder head/camshaft selection/intake.
RRRRIIIIIGGGGGHHHHTTTTTTT
As Brian stated, there's more to this than the flow numbers. The AFR head is a better casting than a factory piece...i.e. thicker deck, smaller water jacket allowing more "meat" around the ports, already comes with bronze guides and large seats installed, intake ports start life at around 170cc's (as cast prior to anyones portwork) so the cnc work cleans up nicely, chambers also start very small so many chamber shapes/sizes are available w/out the need for welding
....the list goes on. Certainly, the benefits would be more advantageous on a high HP build up where the integrity of the head comes into play.
Awesome news! I may have to look into a set
Thanks....
Thanks....
Are these numbers with the same Ti intake valve as with your big-dog 6.0's you posted a while back?
