383 stroker.....600hp build?
383-LS1 -->11.5:1 compression
Promaxx LS3 (small bore) heads-->2.08 intake / 1.6 exhaust valve ---->these flow just over 350 cfm.
cam ~ 238/247-114 (.625/.600)
stock LS3 intake (lightly ported)
full accessories, full weight SS Camaro, 6L80e (3600-4k stall), stock 10-bolt
What HP do you think this will make at either the crank or wheel (your choice)?
BTW, I did see the Richard Holdener video of the 383 that made about 603hp. That was with cathedral port heads/intake, but I want to use the LS3 intake that I already have. The Promaxx LS heads appear to produce similar or better airflow than the TEA ported 243 heads Richard used. I'm just using his video for comparison.
600 hp is certainly not out of the question it’s more of have the entire combo working together.
The Fast LS3 intake only makes about 5 hp more than the stock LS3 intake. It’s not worth an extra $1500.
I was hoping to not go too big on the cam, but you might be right. I think it will get pretty close to 600hp with a cam like that. I think that’s pretty close to what Richard Holdener used. I use his tests as a comparison, because they are repeatable. Like I said before, he used cathedral ports, but the rec ports I listed above provide just as much air. The Promaxx heads have a better valve angle too.
Put a little 78mm in the back where the muffler is. Route your factory exhaust to it. Run one 2.5" pipe to the front and through a smallish IC. You'll be set. 600++ like its nothing on all your factory parts. No reason to bore/stroke or use aftermarket rotating assy with a 600 crank hp goal. if/when it pops drop an SBE 5.3 in and go. "building a motor" with those power goals makes no sense from an economical point of view. I get it if you just want to do it for fun though.
What fuel is available? If you can run E85 you can go higher on base compression. Or skip the intercooler on a little 600chp turbo build.
Here’s a recent Mamo 383. I’d say this is 600 at the crank.
I have Mamo heads, Mamo ported MSD, and a Mamo spec’d solid roller on my sbe LS1. Almost ready for dyno time.
Tony"s 383" was the bogey for my build. Tony"s 383" made 611 HP @ crank on Westechs Dyno & 530 RWHP on multiple Dyno Jets ~6600 RPM.
AFR 225s 320/250 cfm @ .600" on 3.90" bore, Comp Solid Street Roller (.016" lash hot) 242*/248* 114*+0* Ported Fast 90, 11.0:1 Comp, 1.75" headers.
My 393" Big Bore 4.175", MMS LS3 Heads, Fast Mid_Length Runner, Cam Motion LLSR (.008 lash for comparison ) 243*/249* 115* +3* (HR ~237*/243*), 11.7:1 Comp, 1.875" AR LTs.
Made 690 crank HP at the same Westech Dyno 7100-7300 RPM & ~ 590 RWHP @ 6800 RPM on a hub dyno in Mn6 C5.
I think the ProMax heads are about ~240 CC, with a legit 350 cfm @ ..600 on a 3.90" bore you have more then enough cfm for 600 @ crank
With at least 11.5:1 comp, closer to 12 even better, Well ported/rod-mod intake with 1.875" headers should not prevent reaching 600 crank.
Mid -runner Fast would be worth 15-20 spinning 500+ rpm higher, but not needed.
Definitely consult with Cam Motion but something like 235*/243* .624/.612 114*+2* would get the job done, and still drive well on the street.
Just my .02
So, I'd say it's do-able
HP 648/526 TQ
30Kmile LY6
850 Mighty Demon on a 1" open spacer, on a L92 VIC Jr
Edelbrock 1 3/4"-1 7/8" headers
head cut for 11.0:1 compression
OEM pistons flycut .070"
Bret Bauer spec'd cam and valvesprings, pushrods 23X/25X
oem lifters
93 octane pump gas
31* timing, verified with a pinned ATI damper and timing light
12.8 A/F
A Harbor Freight mig is $89! $130 for a nicer one! (don't forget that 20% coupon!) Either way, both are more than adequate to weld up a hot and cold side. I use 110v mig and have made a dozen+ kits. Some have more money than time... I get that. But don't say you can't weld. Anyone can weld. Just a matter of time/effort. I couldn't weld either... so I bought one and welded with it... now I can weld.
I don't know where you get your information from but I can't think of a chassis you'd have to butcher to get a 600hp turbo kit on.
Either way You can add a remote turbo (or have one up front) for WAY under $6k, including the cost of the welder and materials. That's my point. A cam and springs would help, but really you could leave the motor alone. Depending on fuel, an intercooler is even optional. I make well over 600 on a cam only SBE JY 5.3 with no IC on E85. You can make 600hp on decapped stock injectors, paired with 2 AEM400 pumps. You can even mail the ecu out and have a tune put on it. I just did this exact same thing for a bud at work running a 1500 series truck. nothing was butchered and no accessories lost etc.
Simply saying take a look at the forced induction section of this forum. People think they need a lot more than they actually do. Turbos are easy. NA power is MUCH harder and more expensive.
Anyway I won't comment anymore, but if you have any questions feel free to ask. I was going 8's making 900+ with well under 6k in the motor. 600 is a breeze.
i would sell that motor and start over with a 6.0/6.2 and factory rec port heads for basically the same results at way less cost or upgrade intake mani, sbe 6.0/6.2 will break 600 n/a with the right parts
I kinda duplicated one of Richard's tests 2 years ago. It was his truck cam video, where he tested all of BTRs truck cams on a 5.3L (LM7). I used the same 706 heads, stage-2 cam, and TBSS intake, but I had stock exhaust manifolds and flat-top pistons. Richard's test engine had headers and dished pistons. Those were the only 2 differences in our motors. My combo made about 5hp more than Richard's. If I had headers, my engine would have made much more than his. That's why I say his tests are repeatable. I know every dyno could vary a little bit, but Richard Holdener's results are realistic and repeatable.
I have also considered selling my LS1 and starting over with a 6.2L. A cammed 6.2L would be much cheaper, and probably get just as close to 600hp as a 383. The "problem" is, I already have an LS3 intake and a 4" crankshaft. I really want to use both of them.
