Over heating after top end rebuild
Id be greatful for any advice, or troubleshooting steps.
https://www.youtube.com/watch?v=XmWF40ZQNDM
Does the thermostat only block the coolant from entering the radiator? It looks like it might also block the reservoir inlet.
If you work on a lot of cars, I'd suggest a vacuum bleeder for the coolant system. Especially if you have a vehicle that easily gets air locked.
You can also get one of those coolant funnels and make sure it's the highest point in the system, let it idle and let the air work it's way out.
It's a C5 btw to those who asked. But I haven't found many people with major air issues, though I might just not be looking hard enough.
Jacking up the nose with a burp funnel works most of the time for air bubbles but one of those vacuum kits are the best option. They are pretty cheap. Just put he system under a nice big vac, then suck the fluid out of the container.
This kit works well, I've used it many times on LS projects.
$40.
https://a.co/d/hK9BpOX
