Head gasket questions
You should also confirm what rods are in it. Sometimes the engines closer to 2004 production year have the Gen4 rods inside.
https://sites.google.com/site/sloppy...3-or-gen4-rods
Anything over stock is overkill for 8lbs. You literally need nothing to run that kind of boost. Don't over complicate it. Any factory gasket with any factory fastener will do and have a long service life. spendy studs/gaskets aren't going to do anything but hurt your wallet.
Boosted application, 20-25 lbs.
823 heads on a gen 4 iron block
Does a Cometic MLX seal any better than a GM LS9/BTR LS9 gasket?
Cometic MLX GM LS Gen-3/4 Small Block V8 .032" MLX Cylinder Head Gasket, 4.150" Bore .032, .040, .052 (C5014-032, C5014-040,C5014-052)
Cometic MLX RHS GM LS9/LSA Gen-4 Small Block V8 .040" MLX Cylinder Head Gasket, 4.100" Bore .040, .044, .051, .052 (C5985-040, C5985-044, C5985-051, C5985-052)
Cometic MLX LHS GM LS9/LSA Gen-4 Small Block V8 .040" MLX Cylinder Head Gasket, 4.100" Bore .040, .044, .051, .052 (C5986-040, C5986-044, C5986-051, C5986-052)
Cometic MLX GM LS9/LSA Gen-4 Small Block V8 .040" MLX Cylinder Head Gasket, 4.040" Bore .040, .044, .051, .052 (C5505-040, C5505-044, C5505-051)
GM LS9 12622033 4.100" Bore .055 thickness
BTR LS9 - LIKE 12622033 4.100" Bore .055 thickness (cheaper that the above, told it's the same exact gasket)
Why are the Cometic LS9 gaskets different from L and R sides but the GM LS9 gasket is the same part number for both left and right?
