Need good advice on HEAD CHOICE
Old Mar 11, 2024 | 02:15 PM
Capecodder's Avatar
Default Need good advice on HEAD CHOICE
Hi.
I am building a 6.0
Using wisco 11.1 pistons.
i wanted to know if the enforcer head would keep the higher compression ratio. And what chamber size am i looking to get. Please.
And a chopacabra. Cam.
what would be a good head choice please
currently own #317 heads that came on the engine stock. My intentions are with a 5 speed in a mgb and a cAR to beat on..
oh pump gas please.93
Old Mar 11, 2024 | 02:39 PM
What will this be used for, and do now own any heads? If so which ones?
Old Mar 11, 2024 | 03:42 PM
LilJayV10's Avatar
Finding good head sometimes is difficult...
Old Mar 11, 2024 | 03:58 PM
RB04Av's Avatar
Nah man, that's one of the ways beer is better than women.
​​​​​​​With beer, all ya gotta do, is pour it right.
Old Mar 11, 2024 | 08:21 PM
wannafbody's Avatar
If your budget allows go Mamo
Old Mar 11, 2024 | 10:00 PM
01CamaroSSTx's Avatar
How are you determining the 11:1 compression? The 317s aren't bad for a stock cathedral port head but you might look at finding some 799/243 heads. The 862/706s have 61cc chambers and would raise the compression even more. I agree that going to an aftermarket CNC head would be a plus because they do make more power.
Old Mar 11, 2024 | 10:45 PM
Tuskyz28's Avatar
All depends on your dollar...
Old Mar 12, 2024 | 10:48 AM
Capecodder's Avatar
Default Pistons I have installed
Will These will be about 11:1 with a 65cc chamber. Head ?
Old Mar 12, 2024 | 10:51 AM
LilJayV10's Avatar
What's your budget?
Old Mar 12, 2024 | 11:01 AM
gnx7's Avatar
What octane fuel do you have in your area? is this 6.0 an iron block or aluminum? Alum block can tolerate higher compression ratios...
Old Mar 12, 2024 | 06:25 PM
Capecodder's Avatar
I would say medium dollar.
Would the A F R enforcer be a good choice ?
Old Mar 12, 2024 | 06:33 PM
LilJayV10's Avatar
Troll
Old Mar 12, 2024 | 06:34 PM
Capecodder's Avatar
is 11.1 to high . I have. Built small blocks with that compression and also a few 454. Open chamber engines.
I dont want to need additives .with this ls engine. But i like the crispness of a high compression engine also.
Please advise. thanks
Old Mar 12, 2024 | 07:37 PM
Capecodder's Avatar
What's your budget?
head budget 1400 to 1800.
Old Mar 12, 2024 | 11:40 PM
B4CMaro's Avatar
Send heads to Texas speed. Get them ported and milled to desired static compression ratio. Summit racing has a compression ratio calculator as does Wallace racing. Should make calculations easy.
