LQ4 thrust bearing issues
Since the thrust in the LS tends to be whimpy, you most certainly at least want the thrust side halves aligned.
I would measure both halves across the thrust faces and see if they are the same.
I would then install in the block and cap and remeasure.
This will get you numbers to ponder.
Next I would put the cap on, bolts just finger tight and see if you can tap the cap rearward and align the two sides. No crank in just yet. Then tighten the bolts and see if it stays there.
You may end up sanding that top shell which is quite easy with a flat plate, 600 grit and WD40.
If you were able to align the two as mentioned above, sand the forward face.
I’ve not had a lot of luck whacking the crank back and forth to set the thrust. The cap simply tips one way or the other and the clearance changes when you tighten the bolts.
I think you will figure it out from here. 😊
Clearly I’m not in the “send it” crowd.
Ron
Ron
Also, the mating ends of the brg halves may be whacko.
I'd put the brg in, torque it down w/o the crank. What does the parting line look like?
Any dimensional variation from the ft of the brg to the rear when doing this?
