Engine ticking and turned off while driving
Old Feb 18, 2025 | 09:18 PM
Saul0321's Avatar
Default Engine ticking and turned off while driving
2006 Silverado 6.0 bored .30 over 222/226 cam 243 heads
got a rebuild on my 6.0 freshly bored new pistons and gaskets fresh out the shop took it on a 12hr drive cause it felt strong and 1hr away from my destination I starting hearing ticking got louder when I accelerate. 30 seconds later I heard a clashing sounds like if something broke in valve train. Engine completely turned off and wouldn’t start again. What are yall thoughts ? It was completely fresh rebuild with new gaskets and oil pump, new cam bearings completely NEW
lifters and rockers arms, push rods where not replaced
Old Feb 18, 2025 | 09:36 PM
the_merv's Avatar
Pull the Valve Covers and start there.
Anytime using an aftermarket Cam it's a good idea to measure for correct Pushrod length.
Old Feb 19, 2025 | 06:28 AM
RyanChamberlain's Avatar
It helped me, Thank you so much.
Old Feb 19, 2025 | 06:48 AM
1988montecarloss's Avatar
This, probably broke or bent a stock pushrod, always need to measure pushrod length and get stronger aftermarket pushrods when installing bigger cams and stronger valvesprings
Old Feb 19, 2025 | 11:58 AM
Saul0321's Avatar
When I bought the cam kit from Texas speed it came with pushrods and value springs I’m gonna pull the valve covers and hopefully it ain’t something to serious
Old Feb 20, 2025 | 12:57 PM
Then why does your first post say pushrods were not replaced? lol
either way still need to measure
Old Feb 24, 2025 | 07:57 PM
Saul0321's Avatar
Cause i use the same pushrods and springs that came with the cam kit i bought. checked it out it was barley low on oil tried to turn the crank manually and its locked up. Sending it back to builder cause he’s gonna warranty it and find out what happend exactly
Old Feb 26, 2025 | 02:01 PM
still need to measure for the correct length lol
by these comments im assuming it wasnt assembled or tuned anywhere close to correct
