Building LM7
S = Stock J = Jegs
S Exhaust Valve 1.55in
J Exhaust Valve 1.57
S Combustion Chamber CC 64.5
J Combustion Chamber CC 69
Going from a 61.15cc head to a 69cc head will lower your compression ratio to 8.8:1.
Stock vs stock on a mild 5.3, the stock 706/862 heads have been proven to outperform the 243 heads.
You should consider selling the heads and rethinking your whole combo.
It would also lower the cc to around 64
I just thought I got some nice durable heads and wanted to work around them. I mean if all I need to do is mill them down .025 to match the 706 head then all parts would just be direct swap from 706 to 243. Same length pushrods Same size head gasket .051 etc.
I thought it was a good choice to build around them as it has bigger intake and exhast valves than the 706 heads at like 1.85 vs 2inch
But I am just learning in the LS world, I come from Jap crap and germans before this so thank you for the advice. I might consider selling them.
Here is a dyno comparison of stock 5.3 heads vs 243 heads on a cammed 5.3. The stock 5.3 heads outperformed the 243/799 heads everywhere on the graph, with the exception of maybe 1 small blip, in an engine with a greatly increased airflow demand. It would be a shame to have machine work done to your heads just to lose power.
So .025 shorter Pushrod.
And that's if the Jegs Heads are the same Pedistal height as the stock GM LS Heads. Regardless, if you put a Cam in it you need to measure anyway so there's that.
also was recommended that the Truck Norris Stage 2 cam would probably be best for my application.
