Lifter choices
I’m running a 6.0 that ran great when pulled gonna slam a 228/230 .585 with 112lsa cam the
Springs are .625 370lbs / 130lbs
I’d like to shift at 7200 rpm and run 6500 all day
What lifter is suggested ? I figure good ls7 should do me fine so if ls7 is your suggested suggestions on brand so far im leaning toward Howard’s cams 91013 because they said that lifter will do what I want. New trays of course.
im down the rabbit hole of lifter seat height , lifter body height (which I think caused me issues in my last build)
I was googling ls7 gm performance lifters and they seemed to be about the same price as caddy lifters (or maybe a little cheaper) so I couldn't tell if they were the same thing or if gm performance ls7 lifters just means genuine gm ls7 lifters as opposed to another generic manufacturer.
BTR also makes great cams for the top end. What's cool about them is that they test all of their cams on a spintron to make the most amount of power while avoiding valve float and bounce. Btr stage 3 or 4 would make the most sense.
anecdotal maybe but I only speak about what I’ve actually done and not just what I’ve read.
Been spinning it like this for over 5 years
Also, what does 6500 rpm all day mean to you? Are you road racing it where you will actually be up in those rpms all day or is it just a saying not to be taken literally?
IMO either spend the money on johnsons or get genuine gm ls7's if you want to cheap out like I did. No real middle ground for me just my opinion obviously.
Hell if that is true I’m a send it back. I did see a Dino video where it started to fall off close to seven grand. I really was debating if I should get the stage three grind but the duration is pretty high in my last motor. I fucked up when I set it up, so I had some piston valve clearance issues. I use the wrong Spring though. I just figured that out today as a matter of fact now you got me thinking maybe I should switch to the stage three or something different. I like the Elgin grinds because they’re made in America and they’re reasonably priced. I’m not getting the cheap Chinese crap I’m getting the stuff straight from El.
The way I see it, an extra hundred bucks is a drop in a bucket compared to a reasonably sized job like a camswap, and considering the effort and the fact that its going to stay in your engine for a while, you might as well go for the best thing you can. I say btr stage 4.
Damn thinking and talking about it is getting me fired up and those 233/24X, .636, .636, 111 cam specs make me consider going for a big hp build! Can hit 500whp with a good set of ported heads.
My goals are exactly opposite though as I have a street car and am looking to maximize torque between 2000 and 5000 rpms, as opposed maximizing horsepower above 5k rpms. So I am pretty set on the btr Truck norris cam. I won't be shifting above 6500 and likely would rarely go that high. But I dig your build and your goals!
