Low Oil Pressure diagnose
5 PSI idle, barely 20 PSI rev'd.
New Oil pressure sensor- same reading. The used take off oil sender works normally on a different vehicle ( ilde 35, rev'd 60+)
Swapped gauge cluster with known GOOD- same readings on Denali 5PSI idle.
Fresh oil, 7 quarts fill-- Oddly enough, the engine runs just fine and - amazingly makes NO clatter or knock, idle is smooth and quiet, runs great.
I guess we have three possibles:
1) Cam bearing walked itself OUT
2) Oil pump pressure relief valve fell apart
3) Pickup tube O-Ring failure
Proposed TEST for cracked or defective oil pump pickup tube O-Ring :
What if I over fill crankcase, Monitor oil pressure gauge ( at idle) while adding excess oil until O-Ring is submerged. IF O-Ring is leaking I should see an ABRUPT rise in oil pressure as soon as the O-ring joint is swamped in oil, right?
Question: How much oil, approximately , would this take? a Gallon over full? 6 quarts?
I can use low mile drain oil out of any of the fleet, so the experiment will cost nothing./
Is this a reasonable diagnostic tech?
NOTE!!!! If you do overfill, DO NOT rev the engine! You could blow out a seal or gasket somewhere. I really doubt it is the O-ring....
Dilemma: Pull engine, or drop oil pan ?
If it looks ok throw new pump in it snug pan bolts up with 4 bolts at the corners dont even bother with the balancer fire it up and see what the pressure looks like. If its good your money drain oil drop pan and put it all back together completely with fresh gaskets and rtv the 4 corners.
Now, maybe it would've thrown the rod anyway, IDK. All I know is the engine wasn't knocking and had good oil pressure before it didnt. No issues at all. As soon as that engine ran without the balancer, it was turned into scrap in less than 10 seconds!! Maybe it was coincidental, but the engine had no known issues before the balancer was removed. Talk about awesome toys, this guy had that Hemi orange Roadrunner for a couple of years, until it blew up. Bought it in 11th grade while living at home. So what does he do? He goes out and buys a 1969 427/435hp tri-power Corvette!!! Sold the Vette in 1981 for $4,000
Did I mention Bill never married??
....The Best V8 Stories One Small Block at Time
