Rebuild Mentor?
Old Feb 17, 2026 | 11:31 AM
GoFastMiata's Avatar
Default Rebuild Mentor?
Just pulled my L33 out of my Miata. The guy I bought it from said he rebuilt it less than 1,000 miles ago but it was dumping oil into the cylinders. Far as I can tell he didn’t hone the cylinders or gap the rings correctly. I have everything off it except the rotating assembly. I plan to go through it and replace whatever it needs to make it solid. My issue is I’ve never done a full rebuild on an LS. I’ve built simple engines in the past, replaced rings, bearings etc but never had to check clearances and tolerances. I do have a basic know how and have precision tools. Is there anyone that would be willing to mentor me on the full process? I’ll obviously have tons of questions and need some step by step guidance. Even willing to pay somebody for their time since I know this might be tedious.
Old Feb 17, 2026 | 12:25 PM
Ls7colorado's Avatar
wow someone wanting to LEARN!!! thats amazing these days.... were are you located to help maybe find you some assistance locally?
Old Feb 17, 2026 | 01:03 PM
Way out in the sticks of Summerville Georgia. I can’t find any shops that are willing to help in a way that I could learn. Most just want me to hand over everything I have and pay them to do it all. Found a few people on marketplace that advertise LS rebuilds but show pictures looking like they’re building engines in their kitchens with no precision measuring tools.
Old Feb 17, 2026 | 02:07 PM
1FastBrick's Avatar
You can ask questions here. Lots of great people with lots of knowledge on this board.
There is a few books out there on the LS platforum if you want read up.
How to rebuild LS engines from S-A Designs
Amazon Amazon
How to build High performance Chevy LS by will handzel also from S-A Designs
Amazon Amazon
Old Feb 17, 2026 | 03:00 PM
Scott Danforth's Avatar
you probably wont find a shop that will allow you in the back of the building for liability reasons unless you work there. find a reputable shop, talk to the owner, offer to sweep up or run parts for knowledge.
I was lucky, Dad was a machinist, so the tools were available. because of Dad's connections, I knew all the machine shop owners within a 30 mile radius growing up, so I was blessed
ask away, plenty of collected knowledge here.
Old Feb 17, 2026 | 03:11 PM
Before I start tearing down the bottom end, this seems quite a bit excessive. Without putting a micrometer on everything I’m going to assume this is where my oil was coming from.
File Type: mov
Old Feb 17, 2026 | 03:20 PM
LS1Formulation's Avatar
Holy crap, that's excessive. Yeah, you're probably going to need to bore it and get new pistons. I will recommend a couple of things. Do not use plastigauge to check clearances. I tried it on my engine build and it never came out correctly. I bought cheap micrometers from Harbor Freight and checked them against the Starrett ones we have at work and they were basically identical. Buy this Summit dial bore gauge, it's inexpensive but it works really well: https://www.summitracing.com/parts/sum-900041-01 Also buy a rod vise, as it makes it easier to check bearing clearances. Engine building tools add up quick, but it's worth it. If you keep coming back to this thread and post pics and videos with questions you have, I will help you and I am certain people with far more experience will also give you an assist as well.
Old Feb 17, 2026 | 03:33 PM
I actually just got back from harbor freight. They didn’t have a caliper bigger than 3”. I’ll probably have to order one offline so it might take a few days to update this post. I appreciate any and all help!
Old Feb 17, 2026 | 05:07 PM
A leak down test will tell you if it's rings, etc
Old Feb 17, 2026 | 05:32 PM
Gofastmiata, I’m in Dawsonville and I’m happy to help. Shoot me a private message. I help a lot of guys here, both in the states and abroad. I’ve been doing this for over 3 decades.
Old Feb 17, 2026 | 07:32 PM
Welp, looks like I’ll be looking for another short block 😔
Old Feb 17, 2026 | 07:35 PM
tried to pm you but it won’t let me. I’m guessing my account is too new to send pm’s
Old Feb 17, 2026 | 07:44 PM
1FastBrick's Avatar
Yes account is too new. He will get you straightened out. He should be able to send you a message though.
Old Feb 17, 2026 | 07:55 PM
Sent you a private message. Let me know here if you can’t open it.
Old Feb 17, 2026 | 08:25 PM
A guy supposedly just rebuilt this engine less than 1,000 miles ago. When I drained the oil, it was very thin and smelled strongly of fuel. At this point I’m going to assume an injector is hung open and it was ran too long and fried all the bearings. I’m guessing I’ll need to throw in a set of new injectors along with a new motor so I don’t end up in the same scenario
Old Feb 17, 2026 | 08:44 PM
Dont guess or assume here. You’ve got my number.
Old Feb 18, 2026 | 05:43 AM
agree with above, dont guess or assume. test, troubleshoot and verify. parts cannons are expensive to fire.
Old Feb 18, 2026 | 08:03 AM
Sent you a text last night. Lemme know if it didn’t come through and I’ll resend.
Old Feb 18, 2026 | 10:07 PM
I got nothing….
Old Feb 19, 2026 | 02:56 PM
I got nothing….
I sent a second text. Are you sure you gave the right cell number in the pm?
