Compression ratio for 92 octane?
No E85, no octane boost additives. The car is used primarily for HPDE track days.
Asking because the engine was accidentally made with too high a compression ratio (11.8:1) and the builder has offered me a few options to set things right.
Dart aluminum block, 4.185 bore, 4.125 stroke, so 454ci, in a C5.
Thanks in advance for any insights...
But, does DCR really matter at high throttle + high RPM? I mean, I thought that the whole point of keeping the intake valve open into the early part of the compression stroke was to use charge momentum to squeeze even more air into the chamber. What would be the point of leaving it open past BDC, if that was just pushing the intake charge right back into the manifold?
The tuner was pretty sure I had a compression ratio problem, and it turns out he was right. At the time, the builder insisted it was 11.5:1, which seemed reasonable to me since that's what I'm told my LS6 had. (A previous owner did the heads, but the shop that upgraded the cam for me measured the volume and did the math while the heads were off.)
The tuner at the shop that has the car now thinks that even 11.5 is excessive. We're going to talk a bit more before I commit, but I wanted to get some more data points in the meantime. And this is all I can think about this weekend anyway.
I'm amazed that 12.42:1 works for you on pump gas... what AFR do you run and what's your max timing at full throttle / high RPM?
It might also be relevant that I'm running a P59 PCM and (of course) a 24x trigger wheel. I gather that more resolution and more CPU power makes for more accurate spark timing, but I have no idea how much that matters in practice.
It's my understanding that the whole principle of DCR stems from the idea that when the piston rises from BDC to IVC, it is pushing air out of the cylinder, so it only compresses the air that remains in the cylinder after IVC.
And yet the whole reason for trading a stock cam for one with a later IVC is to get more air into the cylinder, especially at wide open throttle and high RPM.
So, I don't see how DCR is relevant to what's going on at (or even anywhere near) peak power.
What am I missing?
What am I missing?
Even while the pistons is starting upward on the compression stroke, air is still rushing in to fill the vacuum. Holding the valve open longer after BDC will help.
The key being to find that sweet spot where the cylinder is full, the intake valve can close, and the piston hasn't made it too far up to lose too much compression.
The key being to find that sweet spot where the cylinder is full, the intake valve can close, and the piston hasn't made it too far up to loose too much compression.
The question is, what's the point of DCR? The DCR is based on the idea that the true compression ratio is determined by the IVC, and therefore is lower than the static compression ratio - which just means that it doesn't take into account any of the facts that you just covered.
If anything the "real" compression ratio is larger than the static compression ratio because the air mass is great than that what the static compression ratio alone would indicate. Whereas DCR gives you a ratio that's smaller.
The rest of the intake and exhaust track are going to "like" the later ivc as well as early evo regardless of overlap when talking increases in scr over stock
What I don't get is why so many people insist that DCR is important when tuning for peak power - full throttle and high RPM.
What am I missing?
What am I missing?
