Odd noise while cranking
Old Apr 7, 2026 | 01:55 PM
Guitarshredder's Avatar
Default Odd noise while cranking
Can anyone help identify this noise? This is a fresh build, engine runs fine just has this odd noise. Gen 3 crank, gen 4 rods and wiseco dome pistons
https://drive.google.com/file/d/1KyT1YDxb9WYgAqjtIX1wiEmTIrCXd8EA/view?usp=drivesdk
Old Apr 7, 2026 | 02:16 PM
02EBC5Z06's Avatar
So for one, it sounds like you have no compression on a cylinder or two.. But then it also sounds like a lifter squawk like when they get turned sideways on the cam.
What are the other details of the engine.
Old Apr 7, 2026 | 02:18 PM
Cadillac racing lifters,polluter v2 cam, wilks 243 heads stock bore everything is new minus the rods and pistons
Old Apr 7, 2026 | 02:19 PM
https://drive.google.com/file/d/1hCm...w?usp=drivesdk
Here it is running
Old Apr 7, 2026 | 02:25 PM
Also wanted to note I have coolant coming from a header bolt near cylinder 3. Idk if its a blown gasket or cracked head, no water in oil and that happened after first drive,temp got to 230 once(had air in the system)
Old Apr 7, 2026 | 02:27 PM
02EBC5Z06's Avatar
Running it sounds fine.
Old Apr 7, 2026 | 02:30 PM
Exactly so idk what that could be?
Old Apr 8, 2026 | 08:07 AM
Anyone know what it could possibly be?
Old Apr 9, 2026 | 09:56 AM
https://drive.google.com/file/d/1cUZ...w?usp=drivesdk
https://drive.google.com/file/d/1cer...w?usp=drivesdk
Here's a few more where you can hear it.
Anyone know what it cou possibly be?
Old Apr 9, 2026 | 12:28 PM
RB04Av's Avatar
Sounds like a flex plate issue. Loose ring gear or some such.
Old Apr 9, 2026 | 01:17 PM
I believe you're correct, I've thought the same thing and wanted to have a few other ears hear it and see what they thought. Thanks everyone i really appreciate it! 💙
