Rockers only swap?
So given that, I was looking into cams and realized after talking to a number of folks that even if I added the most meager of cams (e.g. the lowly 212/218), I would really need a higher stall to take advantage of the increased power band up high. And I'm unwilling to get a TC that slips more than stock and generates more heat, plus I don't want to deal with pulling the tranny and swapping the converter, and I don't want issues when towing. So I'm 95% sure I'm not putting a cam into my truck.
Then someone suggested rockers only. Specifically, the SLP 1.85:1's in place of my stock 1.7's. This way, I could keep the driving characteristics of the stock cam's durations (191/190) while increasing the lift from stock (.466/.457) to right around .510/.500.
So if this is possible, I have a few questions:
1) SLP says +18 HP...what about with the Radix?
2) Can I stick with stock springs/retainers (do I have LS1 springs)?
3) Labor time for (a) rockers only, (b) springs/retainers/rockers?
4) Considering my needs, is this a worthwhile mod?
Thanks in advance.
so $300, 1 hour work ... couple of ponies ... i think it's worth a try
Have you considered something besides mechanical mods? Today's gasoline ain't worth much ; anything to improve combustion of this "horsewhiz" would help you out! Octane is one thing, even racing gas (110,112 octane) is "less" than it used to be ....
My 2 cents worth : check out <www.freewebs.com/goodgas/> ...use Google,link.
Peace! Things are not as difficult as they first appear!
