GM or Cometic Gaskets
Old Jan 7, 2003 | 03:29 PM
QuickSilver's Avatar
Default GM or Cometic Gaskets
In the next few weeks I will be installing a Stage 2 H/C setupon my car and need to know what gaskets to use.
Im looking for about 410 RWHP and want to also add a wet 100-150 shot.
I will be using ARP head studs.
I have heard that the GM ones hold up well, but i have also heard good things about the Cometics.
If i go GM what part # to use??
Thanks
Josh
Old Jan 7, 2003 | 03:36 PM
GeorgeC's Avatar
Default Re: GM or Cometic Gaskets
IMHO, I'd stick with the GM gaskets for your application. The Cometic gaskets are great if you have a larger bore size, or need a gasket with a different compressed thickness.
The Cometic gaskets are fairly expensive compared to a stock GM gasket, and I've seen lots of folks have sealing problems with them.
Old Jan 7, 2003 | 03:41 PM
Thanks George.
Got a PN by chance??
One other thing i have heard is use the truck head gaskets. Or are they just the same?
Josh
Old Jan 7, 2003 | 04:26 PM
y2khawk's Avatar
What size bore, and what base head castings do you have??
I'm running GM MLS gaskets, 6.0 Truck due to the chamber size on my heads.
Old Jan 7, 2003 | 04:28 PM
2001 LS1 SS's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by y2khawk:
<strong> What size bore, and what base head castings do you have??
I'm running GM MLS gaskets, 6.0 Truck due to the chamber size on my heads. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yeah keep in mind GM has both MLS and graphite, which ones are you thinking of?
-Dave
Old Jan 7, 2003 | 04:45 PM
Argon Z's Avatar
go with the tri-metal gm gasket.
DOes somone have the pn for these
Old Jan 7, 2003 | 05:36 PM
LS1derfull's Avatar
Fel pro race gasket all the way and no seeping water issues like MLS style gaskets!
Old Jan 7, 2003 | 07:27 PM
How much do the Fel-Pro's run??
I just have a stock bore size so i guess i dont need the truck ones.
Any part #'s??
Thanks
Josh
