what should i order with a cam??
Old Sep 4, 2004 | 05:55 PM
Nasty Hawk's Avatar
Default what should i order with a cam??
I am about to order a TR 224/224 112 cam. Need some help on what else 2 get from thunder racing. was going to order COMP springs#26918, also Comp titanium retainers #772-16, also Comp hi-tech one piece chromemoly pushrods. Is there anything else i may need or anything here i dont need for installing a cam?? please throw me a suggestion so i can place an order, also to make sure everything is done correct. thanks,,
Old Sep 4, 2004 | 06:14 PM
cyphur's Avatar
sounds like you have everything. make sure you get a gasket and bolt kit while you're at it. don't want to forget that
Old Sep 4, 2004 | 06:49 PM
Lucian's Avatar
i would suggest some mechanics gloves (maybe kind of a gay thing, but it saved my hands from a lot of cuts. Also, I can grip better with them, therefore it is easier to break bolts free. For instance, when i was getting my crank pulley off I had my hand the wrong way and i fractured one of my carpals, at least it sounded and felt like it)
I would also visit JMX's www.ls1howto.com to get the rest of the list of the odds and ends like anti-seize, gasket maker, loc-tite.
I would go ahead an buy some new spark plugs (and plug wires if you want), since they will already be out and all. just dont be an idiot like me and put loc-tite on them. I was paying attention to what i was doing and put it on them (yeah...that is going to suck later)
A degree wheel would also be good to verify you are at TDC to be on the safe side. Majority of people just line them up dot to dot, but i lined mine up dot to dot and then degree'd it and it was 1 degree off (yet there is error in every calculation performed)
What spring tool did you get? the $40 tool from KD will work for single springs like the 918's. Also, the tool vinci sells is very nice.
Oh yeah, lots of towels (red rags and the shop towels)
hope this helps
Old Sep 5, 2004 | 01:46 AM
Z28Venom's Avatar
www.ls1howto.com
The F-Body Cam swap guide has a complete list of everything that you'll need for the install..
Old Sep 5, 2004 | 10:58 AM
WS-Sick's Avatar
I know that the spring swap is the most complicated (even though I haven't done it myself). There are tools out there just for that part of the installation.
Old Sep 5, 2004 | 02:24 PM
Nasty Hawk's Avatar
Think i should get a new timing chain?? if so what brand and stlye?? also should i get a ls6 ported oil pump?? car has 25,000 miles. i dont ever really take it to the track maybe twice a year, just mainly street race it here and there but not very often.
Old Sep 5, 2004 | 06:06 PM
Lucian's Avatar
a timing chain would not be a bad idea, such as a JWIS chain or i am sure some other people could chime in and give some other ideas. I dont know if you need a double roller, especially if your pulley is old, may have to get it machined.
since you have an 02, i dont think you will see much of a gain with the oil pump. if you had a 98-00, I would definately suggest it, but you are probably good. In fact, i bought a ported LS6, but i would have just gotten the LS6 pump (like you have) except time would not allow that.
also, i suggest getting a pen magnet even if you decide to you the 5/16" rods
Old Sep 5, 2004 | 07:20 PM
Predator's Avatar
Why not put on new belts, a new pcv valve, and some plugs too.
Old Sep 6, 2004 | 01:06 AM
Lucian's Avatar
I would go ahead and replace your fuel filter while you are at it as well
Old Sep 6, 2004 | 01:58 PM
Trevor_00Ws6's Avatar
i wouldnt go with the hardened pushrods since your an m6. If you happen to misshift with the hardened pushrods, it wont bend, it will just screw up a valve or something worse.
Stick with stock pushrods, if you bend one, no biggie, just change it.
