Getting a set of TEA heads
Old Sep 10, 2004 | 03:46 PM
RedDragon009's Avatar
Default Getting a set of TEA heads
I have a 01 Trans Am M6 and I am getting a set of TEA stage 1.5 5.3 heads milled .015 and I wanted to know what cams people are running with these heads and what kind of numbers you are seeing.
Old Sep 10, 2004 | 04:04 PM
Scalpel's Avatar
You will NOT be disappointed with those heads.
Old Sep 10, 2004 | 04:17 PM
equandt's Avatar
I have at TR220-114. No heads yet but you picked the ones that will be on my car next spring.
228 duration and under are ideal for those heads.
Old Sep 10, 2004 | 04:22 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
Check out this old thread of mine:
https://ls1tech.com/forums/dynamometer-results-comparisons/178830-tea-1-5-5-3l-tsp-231-237-results-cam-only-vs-h-c-s-provided.html
Old Sep 10, 2004 | 04:53 PM
Bhogan909's Avatar
Our 1.5 heads have been making KILLER power with a Comp Grind we use. It's a 230/226 .573/.570 on a 112. This has made 437 through a 10 bolt on our dyno and has made 408 through an A4 on our dyno. Normally anything in the high 220 to low 230 range in duration is the key to a good Street/Strip setup with our heads. We like to keep the split 4 degrees or less reverse or standard.
Old Sep 10, 2004 | 05:01 PM
David Gordon's Avatar
I had a set of TEA 1.5s with a 224 cam and it performed great.
Old Sep 10, 2004 | 05:09 PM
!LS1 11 Second Club
Hmm. So, the logic here is that the stock exhaust valve found in the 1.5 warrants less need for large exhaust duration on a cam? Hence, the reverse split?
Old Sep 10, 2004 | 08:00 PM
Hardtop's Avatar
I have an early set of TEA stage 2's and they really like the Thunder Racing TR230/224. See sig.
Bruce
Old Sep 10, 2004 | 08:14 PM
JaSSon's Avatar
I made 413rwhp in a A4 with the X1. No better porter out there!
Old Sep 10, 2004 | 08:45 PM
FASTONE's Avatar
Best advertising there is, right Brian!!You need to add this to the cylinder head discussion!!NO HERE!!
Old Sep 10, 2004 | 09:11 PM
The cam I was looking at is the F11 228/230 .581 .591 112 + 4 and I was wondering if I could install a set of 1.75 or 1.85 rocker arms?
Old Sep 10, 2004 | 09:22 PM
!LS1 11 Second Club
Are your pistons flycut?
Old Sep 10, 2004 | 09:26 PM
No they are not
Old Sep 10, 2004 | 09:27 PM
!LS1 11 Second Club
I suggest stock rockers.
Old Sep 11, 2004 | 05:24 PM
LSUxBlake's Avatar
Since you are getting an F11, you should call talk to Allan at Futral about rocker arms. He will ALWAYS suggest stock rockers, as he hasn't seen any gains on a dyno with aftermarket rockers and often encounters problems after 6400 rpm with them.
Old Sep 11, 2004 | 06:50 PM
pdd's Avatar
pdd
very nice heads. you wont be sorry
Old Sep 18, 2004 | 10:45 AM
WS6 #3392's Avatar
You can see in my sig what kind of power and tq I made. I love the set up that I have.
