#317 Vs.#035 Heads - Whats the difference?
- They both have the same size combustion chamber.
- They both had the "D'" shape exhaust ports.
- They are both made out of aluminum.
From the way it looks, after you get them ported, shouldn't they flow the same?
317 = Sand casting vs 035 = diecast.
Can't remember which is better.
Patriot did buy 100s of the 035 diecast, so I would think that
it would be the better of the two.
Dave
I found two casting numbers, casting number should be either 317 or 035 (02 and up LQ9 6.0 aluminum heads)
Specs:
LQ9
01+ 6.0L Truck
Material: Aluminum
Combustion Chamber Volume: 71.06cc
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
Maybe Shaun @ SMC can chime in (or someone bump him this post). I heard he has these heads at a good price.
ValveGod@aol.com
# 241 = LS1 /01 & up ---------- #243 = LS6 01/04 Also try this Link
https://ls1tech.com/forums/new-ls1-owners-newbie-tech/213148-jrp-s-faq-commonly-asked-questions.html
