the TSP magic stick m3
Old Sep 27, 2004 | 01:17 AM
Z-286speed's Avatar
Default the TSP magic stick m3
How are people liking the new cam?
Old Sep 27, 2004 | 02:09 AM
hitmeoff's Avatar
id like to know how streetable this cam is...is this the cam your talking about? TSP Magic Stick v.3 ("MS3") Camshaft: 237/242, .603"/.609", 113 LSA
Old Sep 27, 2004 | 12:08 PM
F1_SS's Avatar
Thats it, TSP said they were selling like crazy but i guess people havent installed them in yet.
Old Sep 27, 2004 | 02:45 PM
2MuchRiceMakesMeSick's Avatar
That cam on a 113 lsa shouldnt be bad at all on the street. I wonder what kind of power it puts down.
Old Sep 27, 2004 | 02:57 PM
cyphur's Avatar
https://ls1tech.com/forums/search.php?searchid=762188
it puts down some wicked power. drivability is pretty good, especially if your tune is good and you have the supporting mods(gears/stall).
Old Sep 27, 2004 | 03:38 PM
cfcoates's Avatar
I've been driving my Magic Stick r3 on the street for a month now. This was my first cam so i don't have much to base it on, but this thing is insane.
Here's the rumble:
MAGICSTICKr3
Old Sep 27, 2004 | 04:27 PM
Full-Force's Avatar
that sounds bad ***! ...
i would like to know how it responds if you nail it with the rpm's kinda low, like 2000 or so .... does it instantly pull like a sack of hell or is a stock cam more peppy down that low
reason i ask is because, lets just say that you ease away from a redlight and then lay into it ... well i want the car to take off like a bat out of hell rather than running so so and then pulling like a raped ape once it gets up to 4000
Old Sep 27, 2004 | 05:38 PM
cfcoates's Avatar
this cam is meant for high ratio gears. i still have 3:42's so i really shouldn't comment on the low end because that just wouldn't be fair, but i will say that i am more than happy with the way this cam runs at ALL rpm's... and this is with a stock tune at the moment.
Old Sep 27, 2004 | 05:46 PM
WS-Sick's Avatar
I think I will swap over to the magic stick after I do heads, clutch, and a rear this summer. It should make some good numbers with a nice set of heads.
Old Sep 27, 2004 | 06:24 PM
mikes02ls1's Avatar
I have that cam, needs steeper gears. I love this cam.
Old Sep 27, 2004 | 06:57 PM
cfcoates's Avatar
are your times from before or after you put this cam in?
Old Sep 27, 2004 | 07:17 PM
mikes02ls1's Avatar
After, I'm also getting better at driving.
Old Sep 27, 2004 | 07:27 PM
WildBills Toyota's Avatar
Here's the rumble:
MAGICSTICKr3
power?
Old Sep 27, 2004 | 07:47 PM
cfcoates's Avatar
still waiting to get on a dyno
Old Sep 27, 2004 | 08:04 PM
harv's Avatar
well i am going to get that cam i have full bolt ons and a tci 4000 stall with 373 gears it should run great i would hope. Car weighs 3550 with my big 325lb *** in there. what dynos are the a4's making??
Old Sep 27, 2004 | 08:46 PM
Full-Force's Avatar
Im assuming that cam can go in a stock motor with no clearance issues? I dont know how they did it but this LS1 has high compression and can run some hella big cams without hitting the pistons.
What springs do they suggest for that cam?
Old Sep 27, 2004 | 09:21 PM
cfcoates's Avatar
this cam clears pistons on engines with stock unmilled heads. the first a4 they put this in made over 400rwhp with only bolt-ons - search for the post.
Old Sep 27, 2004 | 11:05 PM
CamaroCain's Avatar
I am running the V1 cam which is close (238/242 .605/.610 112+4) and I drive the car all the time on the street with this cam. Mine pulls instantly. Like today I was normally coming up to a light and all the sudden it turns yellow so I lay into it to make it through and it didn't hesitate one bit.
Check out the lines on my graph www.texas-speed.com/caindyno.jpg
I also have the TSP race heads on the car too
Old Sep 27, 2004 | 11:42 PM
fastsspr's Avatar
How much is the price for this cam?Can i use comp.cams 918 springs with it?I think i already finished my decition on wish cam to choose!!!
Thanks
Old Sep 27, 2004 | 11:50 PM
mikemodano9c's Avatar
Thanks
no buy some dual springs
