Blown head gasket!
Old Sep 27, 2004 | 08:04 PM
Y2KSS's Avatar
Default Blown head gasket!
I developed a coolant leak on #3 cylinder between the head and block. I think it happened on my last nitrous pass. The #3 spark plug tip was burned off when I took it out and when I pulled the head off tonight the gasket was blown on that cylinder. So my question is, what head gaskets should I be running with my setup? See sig
Thanks
Old Sep 27, 2004 | 08:24 PM
Billiumss's Avatar
I just had a head gasket go on me too, this time I went with the MLS gaskets. So far so good...
Old Sep 27, 2004 | 10:19 PM
Y2KSS's Avatar
Anyone else?
Old Sep 27, 2004 | 10:33 PM
LASTLS1's Avatar
6 Second Club Moderator
Cometic is the strongest gasket for nitrous IMO. But if your detonating, you need to solve your problem. What's your timing at? What plugs are you runnig? What size shot are you using? The head gasket is the weak link. Much worse will happen. I also have to pull my heads off tomorrow. I was told I had some smoke-coolant smell out of my exhaust? I can't get it to do it again! I'm going to pull them just to be sure it's not a block or a gasket. Good luck. Andy.
Old Sep 27, 2004 | 10:44 PM
goober35's Avatar
U can use the cometic or the GM metel gaskets. Might want to invest in some head studs also.
Old Sep 28, 2004 | 11:30 AM
Y2KSS's Avatar
What about Fel-Pro or Victor(napa) gaskets?
Old Sep 28, 2004 | 12:48 PM
cyphur's Avatar
well you could go that route....but i'd really suggest getting GM metal or cometic.
Old Sep 28, 2004 | 03:08 PM
427's Avatar
427
The GM MLS gasket should do fine. If you are blowing gaskets it is the tune up, not the gasket you need to look at. Good luck.
Kurt
Old Sep 28, 2004 | 04:46 PM
Y2KSS's Avatar
Kurt
The gasket that blew is graphite and this is the first. I have several nitrous passes on these but was just wondering if I should be using something better like the MLS gaskets.
Old Sep 28, 2004 | 04:54 PM
427's Avatar
427
The MLS gasket is better for sure but the graphite would hold up to pretty high power before it blows. The spark plug tip being gone is not caused by the head gasket. Sounds like something in your tune has changed to cause you these trouble's.
Kurt
Old Sep 28, 2004 | 05:12 PM
LASTLS1's Avatar
YOU ARE DETONATING!! You need to solve that problem. Then the headgaskets won't blow. Change your tune up. If you answer some of the questions I asked we maybe able to help. Andy
Old Sep 28, 2004 | 07:22 PM
Y2KSS's Avatar
I'm running a mail order tune from TSP, NGK TR55 plugs, and a NX 100 shot. All the other plugs looked ok, and I went ahead and pulled the other head off tonight and everything looked good.
Old Sep 29, 2004 | 08:58 AM
LASTLS1's Avatar
I would switch to tr6 plugs. 93 pump gas at least. Also use Shell, Amoco, or Mobil gas, trust me is DOES make a difference. If it's a dry shot you may be running a little too lean on motor. Do you have a scanmaster? I ALWAYS run one on my dash. I have let off a few times when ever I see KR! When I'm spraying I keep a close eye out for any KR! Good luck.
