Cam advice? Split, reverse split or equal?
Old Oct 13, 2004 | 05:45 PM
  #141
mrr23's Avatar
Originally Posted by Cstraub
yes.
Chris
thank you chris. at least we are on the same page now.
Old Oct 13, 2004 | 06:24 PM
  #142
Sport Side's Avatar
I wrote:
Yes Mrr23. And I think thats why Mr. Straub made a good point by giving an example of this nature: his camshafts may start out as a traditional split at a given lift, but might be a reverse at another.
I dont know how many times I've said, the whole combination thing, but yet you keep going back to what i said in the 216/220 thread. Jarrod and Chris both have said, it is a restriction. (80%) range. So, whats wrong with saying were intake restricted and a reverse split may work better?
and how you are (oh geez -->) stereotyping
you don't have to be mean. I just thought it was silly that I'm using that word in a camshaft thread.
so far the only results i've seen any benefit of having a reverse split cam is if you want to turn past 5500 rpms? i can only draw the conclusions i have with the evidence presented in front of me.
Thats true, and I dont blaim you for it. But as a few have said, if you match it up to the flow characteristics, perhaps at given lift points spec'd you might see a reverse split pattern.
yes between him and me it's a pissing contest.
not to me. just difference of opinions on this matter. i'm not trying to be a jerk. sry if i come across like that.
and he hasn't it's taken others to try and help him justify it.
so? have they not?
it takes alot to sway someones opinion. and i am way to lazy to try and make you feel the way i do. others have layed down some facts. thats good enough for me.
Old Oct 13, 2004 | 06:43 PM
  #143
mrr23's Avatar
now you are saying the whole combination thing. but over in the 216/220 thread all you kept coming back with is the LS1 intake is restrictive. and i asked you to show me why it is. you didn't. hell i pointed you over here and even tried to help you out with proving your point. but, like you said, you are too lazy to prove your point. it's taken many posts and a couple people to help me get a better grasp of a reverse split cam and it's effects. i don't take people at their word. i want to see proof.
here's another little saying i go by. believe none of what you hear and only half of what you see.
one day we'll have to meet up and hang out. i like people that stand up to their beliefs. and will defend it until proven otherwise. as you can see, that's me.
i'm glad to see you aren't taking offense to all this. it's all in learning. but i was getting tired of the poking at me with the stereotyping thing and all.
Old Oct 14, 2004 | 12:05 PM
  #144
GrannySShifting's Avatar
Is there a fast VHP car?
Old Oct 14, 2004 | 02:14 PM
  #145
PREDATOR-Z's Avatar
I dunno for sure but I would say they are more street oriented, than strip.
Old Oct 14, 2004 | 04:37 PM
  #146
mrr23's Avatar
have you looked on their site and found their 9 second Z06? and all the other client's rides that are in the 10's as well? http://www.vincihighperformance.com/...0HOMEPAGE.HTML
oh, and in the 70s when roger was running 10s with a 4 cylinder
http://www.vincihighperformance.com/...SMAINPAGE.HTML
Old Oct 14, 2004 | 09:37 PM
  #147
What did it take to run 9s with that car? Is it fast for what it is or is it just fast?
Whats a fast VHp heads/cam car?
Old Oct 14, 2004 | 09:44 PM
  #148
mrr23's Avatar
the Z06 was a 415 cid 2 stage n2o. ran 9.60s. their 99 c5 test car on that page was a heads cam car. ran 11.44 @ 122 the current 03 c5 has run 12.07 @ 113 cam only. and on DRs. if they ever put ET streets on it, it'll go 11s. heads are next on the list though. but the 03 c5 is their street racer version.
http://www.vincihighperformance.com/...ARPARENT2.HTML
Old Oct 14, 2004 | 10:28 PM
  #149
thats not really all that fast
Old Oct 15, 2004 | 07:36 AM
  #150
PREDATOR-Z's Avatar
Alittlefasterthanyou wouldn't you agree??
Old Oct 15, 2004 | 11:23 AM
  #151
Sport Side's Avatar
Got my latest issue of Chevy High Performance. They did a Patriot Performance head/cam setup. They offered the head flow numbers, so I thought I could relate it to this thread.
-----In.---Ex.--- %
.100 82 65 79.2%
.200 150 124 82.6%
.300 212 160 75.5%
.400 254 196 77.2%
.500 290 220 75.8%
.550 301 226 75.1%
.600 314 229 72.9%
Now, using J-RODS intake restriction chart. I tacked on and got the following:
.200--84.5%
.300--79.2%
.400--83.3%
.500--85.4%
.550--85.3%
.600--82.2%
It would be nice if we could see what a set of Long Tube headers would do.
Pretty interesting none the less...
btw, those flow percentages were calculated using the LS6 intake restriction figures.
Old Oct 15, 2004 | 01:47 PM
  #152
Sport Side's Avatar
Mrr23,
Just realized you did sorta the same thing with the 5.3 flow numbers I posted a while back:
lift-----5.3----LS6----FAST
.200---72%---73%---74%
.300---67%---69%---71%
.400---69%---72%---75%
.500---75%---83%---84%
.600---77%---84%---87%
Those percentages you posted, (and the ones I figured) dont show the whole scenario, seen as the exhaust was not inplace.
With the numbers you supplied and not figuring in the rest of the setup. Yes, a traditional split might be used inbetween .200-.300 lift
In the one I supplied, a reverse split might be used @ every given lift.
Fair to say people?
Old Oct 15, 2004 | 03:44 PM
  #153
Cstraub's Avatar
Sportside,
What was the cam spec's they used in that article?
Chris
  #154
Sport Side's Avatar
@ .050
226/226 .585 on a 112 seperation.
those were the only specifications given.
Old Oct 15, 2004 | 04:19 PM
  #155
Ed Curtis's Avatar
Exclamation
Originally Posted by SportSide 5.3
@ .050
That looks like specs from one of those Mexican regrinds...
Ed
Old Oct 15, 2004 | 04:34 PM
  #156
Cstraub's Avatar
Thanks Sportside.. . .
Ed,
Behave, got your message. . .I will buzz you money and will take care of it. . .thanks.
Chris
Old Oct 15, 2004 | 04:40 PM
  #157
Sport Side's Avatar
Lift--In.--Ex.--- %
.100 82- 65- 79.2%
.200 150 124 82.6%
.300 212 160 75.5%
.400 254 196 77.2%
.500 290 220 75.8%
.550 301 226 75.1%
.600 314 229 72.9%
I posted this question up earlier. Could someone explain the fluctuation of percentages from when the valve lifts off its seat until peak lift?
Seems that most, start at an intake bias-even out-and then return to the intake restriction.
Any pattern? or in a detailed explanation, what causes this?
Old Oct 15, 2004 | 05:23 PM
  #158
mrr23's Avatar
the reason why the percentage starts off high, then tapers off goes back to the scavenging effect the exhaust has. while the exhaust is getting pushed out the cylinder, it creats a vacuum. this is what pulls the intake charge in. also velocity has another part to play in it. at small lifts, the airflow is very fast because of the small opening. then, as the valve opens farther off the seat. the "hole" gets bigger. now the volume that can get in has increased. and the piston is slowing down because it's reaching BDC. just like the water hose trick. you pinch it off and the stream gets faster.
Old Oct 15, 2004 | 05:24 PM
  #159
Sport Side's Avatar
i was lookin for an explanation of that nature
thank you sir
Old Oct 15, 2004 | 05:27 PM
  #160
mrr23's Avatar
i'm sorry. i thought 12.07 @ 113 was pretty quick considering i do 11.97 @ 118 wow just as quick as me but with 5 less mph. and you do 12.51 @ 112. .5 quicker and only 1 mph. i think there's a lot of torque throughout the whole powerband there myself. that brings back the whole VHP concentrates on torque and some horsepower throughout the whole range.
9.60s 2 years ago was pretty darn quick for the time period.
