Valve spring life
Old Apr 5, 2003 | 09:27 PM
bigSS's Avatar
Default Valve spring life
How long normally do aftermarket valve springs last? I currently have the REV 1116's, how often do you think I will need to change the springs?
Old Apr 5, 2003 | 10:22 PM
Cal's Avatar
Cal
Default Re: Valve spring life
I believe that depends on the lift and ramp-rate of your cam.
Old Apr 5, 2003 | 11:22 PM
DONAIMIAN's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Cal:
<strong> I believe that depends on the lift and ramp-rate of your cam. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Check the sig <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
but it also is gona depend on your driving habbits and how many times you go to the track and so on
Old Apr 5, 2003 | 11:40 PM
Cal's Avatar
Cal
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by stang killer:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Cal:
but it also is gona depend on your driving habbits and how many times you go to the track and so on </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yeah I saw that he has a G5X1 cam if that's what you mean, but I have no idea what the specs on that cam are. Like you say there are other factors also like making sure the engine (springs) are warmed up good before you start winding it out into the high rpms.
Old Apr 5, 2003 | 11:47 PM
DONAIMIAN's Avatar
232/240 with .590 and .6XX. I dont know witch side thoes lift numbers are on, but im pretty sure that its chewing the hell out of the springs.
Old Apr 6, 2003 | 12:00 AM
Robzilla's Avatar
stangkiller isnt that the numbers on the g5x2 cam, or is there even a difference between them?
Old Apr 6, 2003 | 12:46 AM
Fly By's Avatar
Its more like a 229/233 590/580 cam. I dont think its chewing the hell out of the springs, still, even with the G5x2 cam, thats still not as big as some 7liter cams, and they have no spring problems! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Figure on what MTI says for sping maintance on their 422 motors, and go by that <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Apr 6, 2003 | 04:01 PM
LS1derfull's Avatar
Large duration cams make life easier on springs, since lift is spread out over more crankshaft degrees. Rpm is what dictates spring life the most, and how close spring gets to coil bind. Heat is what kills springs and those two things mentioned are the features that dictate springs temperature.Fast lobe accelleration definitely works spring harder but this is mostly critical when spring choice is made. Most driving is not full throttle so a decent spring life cycle can be expected.
Old Apr 6, 2003 | 08:25 PM
Jake99SS's Avatar
I'm closing in on 2.5 years/20,000 miles with a T1 cam in the car and 941 springs. I've broken one spring so far and it was probably close to 0 degrees out when it happened.
Old Apr 7, 2003 | 12:39 AM
bigSS's Avatar
Yeah, Fly By has the specs right.
This car is my daily driver, and I probably take it to the dragstrip once a month. I'm not too agressive on the street. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Estimates?
<small>[ April 06, 2003, 12:40 PM: Message edited by: bigSS ]</small>
Old Apr 7, 2003 | 09:24 AM
Fastest 35th SE.'s Avatar
My best friend had a set of Comp 918s on his car for a year (which cam on a set of GTP Stage 2)When removing all mods, i sent the heads back to crieg to get them surfaced and put double springs on them. He said all the intake valves were bent and 4 exhaust valves were bent. Took the springs off and said that they had really low spring preassure. This is only after 1 year. He had a TR224 cam, which is pretty small. Needless to say i would replace any high performance spring yearly.
Old Apr 7, 2003 | 09:16 PM
LS1derfull's Avatar
Valve float can happen from driver error and this will ruin spring tension very quickly. Once valve float happens springs are damaged, and this lowers the point that it will happen again. Lifter pump up is most likely why valves bent from motor revving past a rpm that springs can control valves, etc. The larger the valves the more spring tension required, this alone can be the reason 918 works great to 7000 with stock valves but heads with 2.08" intakes saw right thru the same spring.
