Gasket part #'s needed for cam swap.
They have a cam swap gasket package that comes with valve cover gaskets, crank bolt, water pump gaskets, timing cover gasket, and front engine seal for about $40. You won't need the oil pan gasket becaus it doesn't need to come off, just drop the pan about 1" and that should give you the clearance you need to mess with the oil dipstick tube/oil pump. Also, I see you're going to use a double roller chain, don't forget to install the washers so the block can get oil pressure.
, though i bought mine for TSP because they were cheaper
. price for basic cam/bolt gasket kit, ported ls6 pump, and rolllmaster double cam to 250 shipped if i remember right. as far as the longer crank bolt check your local hardware store. do a search for the right length and pitch you need.
I believe these are the part numbers you're looking for:
Frong cover gasket- 12558013
Front main seal- 12561244
Water pump gaskets- 12559271
Harmonic balancer bolt- 12557840
