what rods to get
Old Oct 17, 2004 | 07:28 PM
bumpin_records's Avatar
Default what rods to get
im looking to 6.125 rods i see some on ebay for like 395 the are by ams racing . anyone heard of those rods or better yet used them? Im looking at 700-800 hp so can they hold that if not what rods and how much do they run thanks
Old Oct 17, 2004 | 08:04 PM
Lswonder's Avatar
I am running eagle esp rods.
Old Oct 17, 2004 | 08:11 PM
how much hp do you have?
Old Oct 17, 2004 | 08:43 PM
jrp's Avatar
jrp
SN95 Director
answer me this. if your going to spend the money to make 800hp why are you wanting to go cheap on a rod which is an intergral part of your motor . for your power mark i'd look at lunati, crower, or manley rods.
FWIW im using the same rods Lswonder is. my application is n/a and looking at 450rwhp.
Old Oct 17, 2004 | 09:19 PM
i never said i will go cheap i just wanna know what rod for 800 hp i can use why buy a 1000+hp rod when there a one that can support 800 for less?
Old Oct 17, 2004 | 09:23 PM
LOnSLO's Avatar
Sounds like you want the Lunati Pro Mods. Check the Lunati site for more info. Thunder and other sponsors carry them.
Old Oct 17, 2004 | 10:19 PM
Magic Chicken's Avatar
12 Second Truck Club
Like JRP mentioned, the Crower rods are supposed to be really good and they are not much more than the Eagle H-Beams.
Old Oct 18, 2004 | 07:59 AM
ok well i will look in to crowler or lunati thanks guys
Old Oct 18, 2004 | 11:18 AM
2001CamaroGuy's Avatar
I have Eagle H-Beams and don't have a problem going to about 750HP (on spray) with them but doing it again, I would have just baught Lunati Pro-Billets.......
when I add up the cost for the rods ($550) and then add in the $200 for L-19 rod bolts and $50 to resize them, I could have paid the extra $200 and had a rod that is RATED (not "know to work at") at 1100HP.......
live and lean.........then by the right ****
Old Oct 18, 2004 | 11:45 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
We offer Crower LS1 specific rods. That's what I would run, either that or a Lunati Pro Mod
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Oct 18, 2004 | 06:47 PM
Dave00C5's Avatar
You want the best get some Oliver Rods.
Old Oct 18, 2004 | 07:03 PM
moyam01's Avatar
The very best, these rods are used for twin turbo full drag applications. Carillo H-beams. They are also used in the Road Race c5r program from gm.
Old Oct 18, 2004 | 07:07 PM
I know you guys have good intentions, but you're getting crazy. He's not looking for $2000 set of rods (at least that's what I gathered). Eagle, Crower, Lunati will all work just fine for his application.
