best heads?
Old Nov 1, 2004 | 12:10 PM
jimmyblue's Avatar
Moderator
LS6 give you a near-stock CR with no cutting on an
LS1 F-body. 6.0 heads will drop you, 5.3s will raise
you. Dunno about your neck of the woods, but in
Florida I would have a hell of a time trying to run
11+:1 CR on pump gas in the summer.
My present plan involves home-porting truck heads
and shaving maybe 0.050 off them. So far I'm only
in the "slice one thin and see what's inside" stage
(3 cuts done, 2 to go to complete one cylinder's
"CAT scan"; takes half an hour per cut with the
abrasive blade chop saw).
Yes, I will be posting scans. No, I don't need anyone
to ask me if I'm done yet. ;P
Old Nov 1, 2004 | 12:55 PM
Mirek's Avatar
Dart Heads ?
Old Nov 1, 2004 | 01:04 PM
Gunnar@Patriot's Avatar
*We begin with a new GM raw 035 casting where all dimensions are +.050".
*Precision welded combustion chambers.
*Heat treated to T6 specs.
*Milled to OEM height
*5 axis CNC machined.
*Hand detailed and assembled.
*23-8N Patriot Stainless Valves
*Bronze Guides
*Patriot Gold .650" Dual Springs (Why buy imatations when you can have the orginal?)
*Titanium Retainers
*5 Angle Valve Job
*No core required
*Free MLS 6.0 Head Gaskets
*Free OE Head Bolts
*Flow Sheet Included
*100% Pre-Installation Money Back Guarantee
*Things have changed...There is no need to pay more.
Old Nov 1, 2004 | 02:09 PM
WS6FirebirdTA00's Avatar
only problem i hear from patriot around here is the valve or something like that. never heard of a problem with the head
Old Nov 1, 2004 | 02:15 PM
TVWilkes's Avatar
Default PRC heads
Originally Posted by P Mack
PRC heads should be coming out soon. They're priced about the same as patriots and had some good results.
The PRC line of heads is top notch.There will be some of them running this weekend in the thunder shootout.They only have top quality name brand components.They have 2.04/1.585 valves ( Manley ),PRC spring kit all of this is on new castings.
Old Nov 1, 2004 | 02:18 PM
ok i suck at finding these places, whats the site for PRC
Old Nov 1, 2004 | 02:30 PM
VSGLS1's Avatar
Check Terry's profile...
What are you looking to get out of your car...That might help your decision.
Old Nov 1, 2004 | 02:36 PM
TVWilkes's Avatar
PM or email me for details.PRC does not have a website up.
Old Nov 1, 2004 | 02:53 PM
ok thanks, im headed out of class now ill do it tonight
Old Nov 1, 2004 | 03:38 PM
Patriot Heads
WINNER-THUNDER SHOOTOUT 2003
QUICK STOCK DIVISION
Old Nov 1, 2004 | 03:46 PM
goober35's Avatar
I see a lot of post that say witch heads are the best or witch heads should i get.
One that is never mentions and is one of the best sets out is SDPC. You can get a set of LS6 heads for $1900 that have been ported. They are flowing just as much or even more than most of the heads out there and they are using stock vavles.
Old Nov 1, 2004 | 04:29 PM
  #32
Viper's Avatar
But, with the SPDC heads it's stock LS6 valve springs and retainers. I agree, the price is awesome, and you get the lightweight sodium valves. But once you add dual springs to this kit, the price goes to $2200 or so.
Right?
Old Nov 1, 2004 | 05:00 PM
  #33
equandt's Avatar
No one has mentioned GTP heads or LPE heads. Those two guys are the best in the business.
Old Nov 1, 2004 | 07:20 PM
  #34
f-bodman's Avatar
PM sent, I'd like some details.
Old Nov 1, 2004 | 09:33 PM
  #35
TVWilkes's Avatar
Originally Posted by GUNNAR@PATRIOT
Patriot Heads
TSP won the race @ thunder last year.The heads used was not your everyday set of heads.They started life as patriot castings,the rest is not patriot.The heads was completely hand detailed.I performed all of this work at my shop.The motor was shifted at 7400 rpm all day long due to a tranny problem.
Old Nov 1, 2004 | 10:00 PM
  #36
H82BBad's Avatar
I will continue to offer the best priced,highest quality head that I can produce.I have said it many times,that my goal is to offer the best set of heads,REGARDLESS OF PRICE.Yes, our prices are ceaper than most,but on my flow bench I have yet to see a head outflow what I offer.This includes the 5.3 and the LS6 style.
I did not come on here and bash back and forth about flow numbers vs another company or Dyno's vs Dyno's.It does not matter unless they are all tested on the same bench at the same time with the same bore size ect...I want my product to speak for itself, on the track.
With that being said,look at the results from the Quick Stock class from the Thunder Shootout.
um you claimed they were patriot heads back then Terry.
https://ls1tech.com/forums/showthrea...ootout+results
Old Nov 2, 2004 | 01:01 AM
  #37
TVWilkes's Avatar
They were Patriot heads. The heads were completely refinished with Ferrea valves & alot of hand finish work.
Old Nov 2, 2004 | 01:27 AM
  #38
matts22's Avatar
Terry, can you please check your pm/email from me and send me a reply?
Old Nov 2, 2004 | 04:20 AM
  #39
TVWilkes's Avatar
For the record, I have stated 2 times that the heads were patriot castings. My job was to sell patriot heads. Do you think that I wanted to carry a knife to a gun fight? If you race your car in a major event, such as the thunder shootout, your setup better be top notch. My point was to clarify that a set of heads pulled off the assembly line did not win the race. To win an event like this it takes some attention to detail. If a manufacturing company is producing heads there is no attention to detail. Everyone that purchases a set of heads is expecting the best product available, and they deserve it. If you have many sets of heads leaving on the ups truck everyday, the attention to detail is not a concern.
Old Nov 2, 2004 | 04:22 AM
  #40
TVWilkes's Avatar
Matts22, Sorry for the delay of answering your email.I will reply to you later today.
