With heads.. is it true that...
Old Jan 8, 2003 | 06:27 PM
mike#9's Avatar
Default With heads.. is it true that...
When a set of heads have smaller valves that they will not make as much power but could possibly run better times at the track due to better midrange power than a set of heads with bigger valves? I want a set of heads that make great power, but I would be more interested in useable power for the street and strip to run better times, instead of having the highest dynoing heads. Price is an factor..
What would you guys reccomend for me. I want stage 2 heads.
Thanks
Old Jan 8, 2003 | 11:01 PM
Krazy98Z28's Avatar
Default Re: With heads.. is it true that...
3 letters TEA
Old Jan 8, 2003 | 11:32 PM
Slowhawk's Avatar
LS1Tech Sponsor
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Krazy98TA:
<strong> 3 letters TEA </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">4 letters-Jeff <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Jan 8, 2003 | 11:48 PM
mike#9's Avatar
What do you guys think about Absolute Speed stage 2 heads as opposed to TEA?
Does anybody have any feedback on my initial question about the smaller valves?
Thanks
Old Jan 9, 2003 | 02:50 AM
smokin' joe 00 ss's Avatar
I don't think you could go wrong with Absolute the smaller valves will make better mid range power on the stock c.i. motor, big valves work best on the large bore motors. I wanted heads that would do the same thing that you want thats why I ordered stage 2 from Absolute.
Old Jan 9, 2003 | 08:58 AM
GeorgeC's Avatar
I have 2.02/1.57" valves in my heads, FWIW...
Old Jan 9, 2003 | 01:17 PM
mike#9's Avatar
Is MTI and GTP putting up good track times with the stock 346? Would a set up like Absolute Speed have better track times than MTI, GTP? What about track times for TEA?
mike#9's Avatar
Old Jan 9, 2003 | 03:15 PM
SSINFUL's Avatar
You have hit on a big part of it. It's also how the mixture flows into the cylinder. And compression. And injector spray patterns. And on and on.
"Stage 2" is a term that is only applicable from one set of heads to another WITHIN one manufacturer. One Co's Stage 2 may have 2.02 x 1.57 valves, anothers may have 2.055 (or bigger) x 1.60.
Cartek had a story in GMHTP awhile back where they were running close to 10's w/ 2.02 x 1.57 heads.
Old Jan 9, 2003 | 04:25 PM
Serial Thriller's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by mike#9:
<strong> Is MTI and GTP putting up good track times with the stock 346? Would a set up like Absolute Speed have better track times than MTI, GTP? What about track times for TEA? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I'm glad you brought this up. So much of the information out there is just flow numbers. Dyno numbers are a little better, but track numbers would really be helpful (keeping all the variables in perspective).
Old Jan 9, 2003 | 05:50 PM
LS1derfull's Avatar
Big bores allow for more relief in chamber around bigger valves to allow more flow with them.Port design and size has way more to do with velocity into cylinder than valve sizes do. You really cant overvalve a cylinder, but you can definitely over Size port and hurt performance. I have shifted heads around on flow bench bore and it doesnt have the dramatic effect on port flow that people think it would. FWIW
Old Jan 9, 2003 | 05:51 PM
LS1derfull's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by LS1derfull:
<strong> Big bores allow for more relief in chamber around bigger valves to allow more flow with them.Port design and size has way more to do with velocity into cylinder than valve sizes do. You really cant overvalve a cylinder, but you can definitely over Size port and hurt performance. I have shifted heads around on flow bench bore and it doesnt have the dramatic effect on port flow that people think it would. FWIW </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">P.S. Oh and thanks Don!
Old Jan 9, 2003 | 06:09 PM
wolfman jack's Avatar
also keep in mind that every aspect of the cam profile(lift duration c/l and so on) will and can change how much power/tq that you have and when you have it
Old Jan 10, 2003 | 12:27 AM
JFM-jr's Avatar
Thunder 224/224 cam,all the bolt ons,Absolute Speed stage 2's 2.02/1.57.A4 with a PT4400 I have gone a best of 11.04@121.4mph.There is more to be had in weather this was run at -700DA here on L.I. it can hit mineshaft -1500DA's and the car is a lock for a 10 sec run.Unlocked dyno was 405hp we plan on a redyno with it locked for some new numbers.This package kicks tail and at a great price.
Old Jan 10, 2003 | 05:30 PM
LS1derfull's Avatar
Your times and speed are impressive and you are most certainly going to run 10's. How much does your car weigh?
