need help with porting
Old Nov 12, 2004 | 02:36 PM
Silver_Whistler's Avatar
Default need help with porting
I am new to porting out heads. Anyone got any pics of home porting jobs. I need to see how much metal and where to take metal out in a set of 5.3 or 5.7 heads.
Old Nov 12, 2004 | 09:33 PM
M6HuggerSS's Avatar
DO NOT GO BY PICTURES WHEN PORTING HEADS!!!
if i were you id save yourself the time , $$$, and loss of HP, or loss of heads and just go buy a good set from one of our sponsers. jmo.
Old Nov 12, 2004 | 09:55 PM
ace68's Avatar
well if you realy wanted to try get a copy of car craft dec. issue and read the head basic art. that might help to get you started.
Old Nov 12, 2004 | 09:58 PM
thanks
Old Nov 12, 2004 | 10:03 PM
2MuchRiceMakesMeSick's Avatar
If you want a good head job, you’ll want someone with experience
Old Nov 12, 2004 | 10:07 PM
cyphur's Avatar
Old Nov 12, 2004 | 10:20 PM
Turo's Avatar
ttt for ya. id like to see some advice on home porting also, i have an extra set of heads i want to try and port myself this winter. i know the best way is to send them to a professional, there's no arguing that, but i cannot afford the price of ls1 cylinder heads, and i figure i might be able to do just a simple cleanup on them
Old Nov 13, 2004 | 10:35 AM
Bo White's Avatar
Look through the forums under "home head porters" or some variation of that. I have a thread that has this info and so does other guys like us. I can also send ya some of my pix, just pm me an e-mail address.
Old Nov 13, 2004 | 10:42 AM
jimmyblue's Avatar
Moderator
I posted cutaways of 6.0 heads not too long back. Not
much material to take away, I believe the flow gain is
more about art than about removal-in-bulk. Also see
some people just hogging away the "swirl ramp" and
others barely touch it; this I guess comes down to
whether these are "street torque heads that flow a
bit better" or "strip screamer heads, below 5000RPM
fuggedaboudit".
No idea how similar or dissimilar the 5.3 and 6.0 are,
aside from the chamber volume.
Old Dec 9, 2004 | 09:44 PM
M6HuggerSS's Avatar
here are some of the pics of the heads i did....
i got them with a RUFF CNC job ... i put about 40 hours in porting, polishing, CC'ing and assembly.
Attached Thumbnails need help with porting-smallheads.jpg   need help with porting-smallhc8.jpg   need help with porting-smallhc3.jpg   need help with porting-smallhc4.jpg   need help with porting-smallhc5.jpg
Old Dec 9, 2004 | 10:17 PM
you did a really good job. thats about what i want to do.
Old Dec 9, 2004 | 10:34 PM
M6HuggerSS's Avatar
it wasnt hard ... but i did have a PRO watching over my shoulder ....
Old Dec 10, 2004 | 09:30 AM
Bo White's Avatar
Looks pretty good dude, Kudos to your PRO help.
Old Dec 11, 2004 | 08:51 AM
GuitsBoy's Avatar
M6 Hugger, did you say those valves were 2.050 and 1.57? Did you change the seats yourself or have them done. Nice work!
Old Dec 11, 2004 | 02:26 PM
M6HuggerSS's Avatar
when i got the heads they were fully assembled .... but with a ruff CNC job....
and yes... 2.05 and i think 1.60?
Old Dec 11, 2004 | 02:47 PM
Hugger's Avatar
I just got done with a set of 6.0L heads that I had milled .030 and all I really did was just a good cleanup. Just made smooth transitions everwhere I could and took out casting flaws. I found it's really hard to look at a set of ported heads and determine where to take material out. All the research I did lead me to just want to clean mine up and have a very good 3 angle valve job done. You will hurt your performance by going nuts with a grinder if you don't know what you're doing. I just ordered the standard abrasives porting kit and went through and cleaned up the rough areas and casting lines. I have not had the car back to the track since, but none of my porting work seems to have had an adverse affect on the car. I am not expecting huge gains but hope to go a little faster. That's my .02, hope it helps.
Old Dec 12, 2004 | 12:05 PM
M6HuggerSS's Avatar
nice ride there HUGGER!!!! sounds like you did a good job with your heads.....
did you CC, de-burr, and vacum test your heads be fore you installed them????
these are the MOST important things you can do.....
