Will I have P to V issues with this setup?
Old Nov 22, 2004 | 01:49 PM
Hugger's Avatar
Default Will I have P to V issues with this setup?
Here are the specifics:
5.7L Block, stock pistons
6.0L heads milled .035
LS6 sodium filled valves
228/228 dur .571/571 lift 113 LSA cam
6.0L MLS Gasket
Will I have any Piston to Valve issues with this?
-JOSH
Old Nov 22, 2004 | 01:55 PM
Hugger's Avatar
Also I will be using comp 918 springs.
Old Nov 22, 2004 | 02:09 PM
LOnSLO's Avatar
I would think not, but there's only one way to find out.
Old Nov 22, 2004 | 03:04 PM
Phoenix H.O.'s Avatar
i think you will. i had a 224/224 .563 114lsa cam with a set of MTI stage IIr heads that were milled .003 the first wide open throttle attempt i made the valves taped every piston and one valve broke. when took off the heads i saw an indention on every piston where the valves were hitting along with one broken valve jammed up in the valve gide.
Old Nov 22, 2004 | 04:04 PM
JNorris's Avatar
Moderator
6.0L MLS Gasket
-JOSH
What is the ICL of the cam?
John
Old Nov 22, 2004 | 04:35 PM
Hugger's Avatar
I have a bad copy of the cam card, but the ICL appears to be 111
Old Nov 22, 2004 | 07:15 PM
Hugger's Avatar
Anyone else want to chime in?
Old Nov 22, 2004 | 07:22 PM
ArKay99's Avatar
If you don't you will be very close. I would always check anyway. I takes an extra 10 minutes and you will know what it is.
Old Nov 22, 2004 | 08:16 PM
camaross383's Avatar
Josh, I am about to go with a bigger cam also. My heads are milled .055 so I am going to have to flycut.
It might be worth it to cut yours while you have the heads off anyway. I'm going to get all the tools needed to do the job, so let me know if your interested.... What size intake valves on those 6.0 heads?
give me a call.
Old Nov 22, 2004 | 08:35 PM
Hugger's Avatar
Hey Kori, they are just stock LS6 valves that I am putting in the heads.
Old Nov 23, 2004 | 09:52 AM
Those are the same valves I have. So the kit should work fine for you too.
I'll be the guinea pig, and if you want to cut yours after, you can borrow the tools, or whatever. I'll let you know when I'm going to do it. Right now I'm deciding on a cam, right now i'm thinking 236/236 .595 .595 110 LSA
