LS1 Oil Pressure
Old Nov 22, 2004 | 04:40 PM
fastbasser's Avatar
Default LS1 Oil Pressure
What are you guys getting for oil pressure with your oil temp around 190 degrees at idle?
Just curious.
Thanks in advance.
Old Nov 22, 2004 | 05:41 PM
C4VetteLS1's Avatar
Most stock ls1's idle around 25-35 psi that ive seen, occasionally see one with 20 psi at idle warmed up
Old Nov 22, 2004 | 05:47 PM
schultzsj's Avatar
My last motor would get down close to 20 at hot idle. The motor I have now does not go much under 40. The old rule of thumb is 10 psi for each 1000 RPM.
Steve
Old Nov 22, 2004 | 06:01 PM
blkZ28spt's Avatar
Mine idles at 20 hot. If yours is lowish, like ~20, I probably wouldn't worry. It seems like some are just lower than others.
Old Nov 22, 2004 | 06:16 PM
Mooobunnny's Avatar
Mine idles at 40-45 warm.....higher cold.
Chris
Old Nov 22, 2004 | 07:24 PM
BriancWS6's Avatar
Chris
Same here.
Old Nov 22, 2004 | 08:38 PM
68birdls1's Avatar
i got to crank mine up for the first time today and it was a steady 45 psi! i was so stoked to see that i didnt mess up the oil pump o-ring install lol
Old Nov 22, 2004 | 08:42 PM
TraajicLS1's Avatar
45psi .... never dips below 40
Old Nov 22, 2004 | 09:22 PM
Ferocity02's Avatar
55 at idle, 80 at WOT with ported LS6 pump
Old Nov 22, 2004 | 09:32 PM
family sedan's Avatar
Both of mine are 38 psi when warm, same oil in each.
Old Nov 22, 2004 | 10:33 PM
SmaknaSS's Avatar
55 @ idle,80 @ WOT with a ported LS6 oil pump from thunder racing.
Old Nov 22, 2004 | 10:50 PM
01_SuperSlow's Avatar
45 idle, 70-75 wot. with a stock ls6 oil pump.
Old Nov 23, 2004 | 06:27 AM
fastbasser's Avatar
Thanks guys.
Another question if you please.. How much does a ported LS6 pump such as the ones from Thunder Racing raise oil pressure?
Old Nov 23, 2004 | 08:56 AM
SSCamaro99_3's Avatar
I get 40+ psi hot, and 60+psi cold. It gets over 70 as soon as the car passes 3000 rpms. My Katech pump was $119 from RMS back in June 03.
Old Nov 23, 2004 | 10:07 AM
SmaknaSS's Avatar
Originally Posted by fastbasser
Thanks guys.
I don't think I have a high oil pressure due to it being a thunder racing pump, But I could be wrong. I think I was just lucky.
Old Nov 23, 2004 | 08:22 PM
Ferocity02's Avatar
Mine didn't add much, maybe 5-10 psi at the most. Thats what the pressure was stock about.
Old Nov 23, 2004 | 08:54 PM
66deuce's Avatar
about 20psi hot.ported pump from thunder racing.
Old Nov 24, 2004 | 05:03 AM
Patman's Avatar
Mine has an idle oil pressure of 29psi at an oil temp of 200F
At 70mph it's around 44psi (with an oil temp of 200-205)
Old Nov 24, 2004 | 09:23 AM
badpewter-z's Avatar
LS1TECH Sponsor
cold start 60psi
warm idle 45-50
2000+ 60psi+
wot - almost 80psi
this is a h/c cam car too
stock pump too im not touching it when it works that good
Old Nov 24, 2004 | 12:03 PM
alivegy's Avatar
stock 02 z28, mine's never dropped below 40
