402,408,414,422...
Thanks!
the 400 had a rod of 5.565 and a stroke of 3.75 ... a 1.484 ratio ... and it never had a problem with increased oil consumption
No he is correct, do some more research.
The 402, is a 6.0 with a 4" crank.
The is a 404.x is a 6.0 bored 10 over and a 4" crank.
The 406 is a 6.0 bored 20 with a 4" crank.
The 408 is a 6.0 bored 30 over with a 4" crank.
The 414 is a 6.0 bored 60 (which is the extreem) and a 4" crank.
There are 2 422's I believe.
One being a 6.0 bored 30??? with a 4.125 crank.
The other being a aluminum block with a resleeved 4.100 bore and a 4" crank.
I am not positive on the last few but I know I am in the right area. This should give you some examples.
I think a 414 might also be a 4.030 bore using the 6.0 with a 4.125" crank, but again I am not positive.
I personially wouldn't take the 6.0 motor past a 4.040 bore. The sidewalls get thin.
Also if you did have a problem you could rebore the same motor to 4.045 and not have to toss the block in the can.
I would suggest you keep your bore bigger then your stroke. 408 is a 4.030 bore and 4" stroke which gives more bore then stroke.
Better for making power.
Please correct me if I am worng as my memory isn't always perfect.
Would getting this right help with longevity of the motor? What is "right" with this?
